My friends looking into getting a gaming pc. was really wanting the newest from intel, just tried to put together a build that would work well for his needs. Any suggestions
Current Partlist -https://pcpartpicker.com/list/MgWr8Y
https://linustechtips.com/topic/1032186-build-for-a-buddy/
1 minute ago, Votivee said:
If it's in the budget you should throw an SSD in there for a boot drive. SSD's are pretty cheap now.
Yea I tried doing that earlier with a beefier 1060 but it was over his 1k budget. After finding the zotac Im sure I could get a 240 gb ssd Easy. I was concerned with a bottle neck on the 1060 with the 8700k any thoughts? hes newer to pc building so he might never OC
https://linustechtips.com/topic/1032186-build-for-a-buddy/#findComment-12286251
https://www.amazon.com/Kingston-120GB-Solid-SA400S37-120G/dp/B01N6JQS8C/ref=sr_1_5?s=pc&ie=UTF8&qid=1549836785&sr=1-5&keywords=ssd
The 1060 6GB and 8700k are a good match.
~Air Cooling Advocate~
https://linustechtips.com/topic/1032186-build-for-a-buddy/#findComment-12286267
Just now, Votivee said:
I assumed it wouldnt be to much of an issue because im not getting a gpu bottle neck on my i7 5820k and gtx 1060
https://linustechtips.com/topic/1032186-build-for-a-buddy/#findComment-12286272
5 minutes ago, Votivee said:
That's the same CPU I have, except I run a 1080. Do you have it overclocked at all?
I do, Ive kept it at base since Ive gotten it, the motherboard my pc came has its BIOS locked to prevent overclocking. but I have an AIO On it and it runs fairly cool
https://linustechtips.com/topic/1032186-build-for-a-buddy/#findComment-12286326
Bummer, it OCs amazingly. I've got mine up to 4.6GHz stable, and it could probably go farther if I really wanted to put the time in to mess with it.
Good luck with your friend's build!
https://linustechtips.com/topic/1032186-build-for-a-buddy/#findComment-12286352
Wow, thats a really nice OC. if you dont mind me asking what cooler and mobo you use? right now I have a single fan AIO and I really dont know what would be a good mobo
https://linustechtips.com/topic/1032186-build-for-a-buddy/#findComment-12287323
If you click on my profile and scroll down to "System" you can see all the specs for my build. Since we are getting off the main point of the post, if you have any questions or need any help feel free to PM me with the "Message" button at the top of my profile, or add me on Discord (Votive #7780) for a faster reply.
https://linustechtips.com/topic/1032186-build-for-a-buddy/#findComment-12290606
I personally don't think an 8700K is a good match with the 1060; you could pretty close to getting a 1070 with a 9600K, which is basically a 8700K without hyperthreading. You could also instead keep the 1060/9600K and invest in storage/PSU bumps.
Current Desktop Build | 2200G | RX 580 4GB | 8GB RAM | CTRL | Logitech G Pro Wireless
Laptop | 2018 MBA 256/16GB | MX Master
https://linustechtips.com/topic/1032186-build-for-a-buddy/#findComment-12290657
