Hello
i just got 2x 1TB HDDs for my system. I wanted to use them in raid 0 as a storage option. My boot drive is an nvme samsung 960evo. The problem is when I enable RAID (Intel RST premium with optane support) for the 2 HDDs, my nvme drive is not recognized under the nvme configuration tab in bios and my boot drive list is empty.
When i boot my usb stick to install windows the nvme is shown but i cannot install on it (although i could install without the raid). Even if i manage to install windows with some kind of driver or disabling raid and enabling it later, how will i select boot device if the list is empty?
what can I do?
I have
Gigabyte z270 Gaming K3
I7 7700k
16GB 3000Mhz Ram
960 evo 250GB
2x 1TB HDDs
thanks in advance
https://linustechtips.com/topic/1032137-need-help-with-sata-raid/
If you aren't going to boot off of the RAID array and aren't going to use an OS other than Windows, it might be better in your case to go for Windows software disk striping. You can take the disks out of RAID in your BIOS, then use disk manager in Windows to create a striped volume across the two disks. You lose compatibility with other operating systems, but if that isn't an issue it should work fine.
¯\_(ツ)_/¯
Desktop:
Intel Core i7-11700K | Noctua NH-D15S chromax.black | ASUS ROG Strix Z590-E Gaming WiFi  | 32 GB G.SKILL TridentZ 3200 MHz | ASUS TUF Gaming RTX 3080 | 1TB Samsung 980 Pro M.2 PCIe 4.0 SSD | 2TB WD Blue M.2 SATA SSD | Seasonic Focus GX-850 Fractal Design Meshify C Windows 10 Pro
Laptop:
HP Omen 15 | AMD Ryzen 7 5800H | 16 GB 3200 MHz | Nvidia RTX 3060 | 1 TB WD Black PCIe 3.0 SSD | 512 GB Micron PCIe 3.0 SSD | Windows 11
Will I lose the data that is already stored inside the raid 0 drives?
Yes. I assumed you hadn't put any data on them since you couldn't get into Windows and they were wiped when you put them in RAID 0 anyway.
¯\_(ツ)_/¯
Desktop:
Laptop:
I somehow managed to boot into the already installed windows(after 100 startup repairs) before I downloaded windows iso to format
