Hi.
I have a dead cisco catalyst 2948G from 1999!! Was thinking of stripping the old pcb out and putting an embedded atx/itx board and an ssd/ 2.5" hdd in it to make a linux test box that can run 24/7 without trippling electricity bill.
Is this a good idea and has anybody done anything like it before? BTW it 1.5U of rackspace if that helps?
Server 1:  CPU: i3 2100T  SSD: 840EVO MOBO: DQ67OW NIC: i340 -T4
Server 2:  CPU: Pentium D  MOBO: Dell Dimension 5150
Switch 1: Netgear GS108
Switch 2: Cisco 3500
https://linustechtips.com/topic/1031806-diy-rackmount-case/
If you don't need anything very powerful something like a Raspberry Pi or a Zotac ZBOX P series might do the trick.
¯\_(ツ)_/¯
Desktop:
Intel Core i7-11700K | Noctua NH-D15S chromax.black | ASUS ROG Strix Z590-E Gaming WiFi  | 32 GB G.SKILL TridentZ 3200 MHz | ASUS TUF Gaming RTX 3080 | 1TB Samsung 980 Pro M.2 PCIe 4.0 SSD | 2TB WD Blue M.2 SATA SSD | Seasonic Focus GX-850 Fractal Design Meshify C Windows 10 Pro
Laptop:
HP Omen 15 | AMD Ryzen 7 5800H | 16 GB 3200 MHz | Nvidia RTX 3060 | 1 TB WD Black PCIe 3.0 SSD | 512 GB Micron PCIe 3.0 SSD | Windows 11
https://linustechtips.com/topic/1031806-diy-rackmount-case/#findComment-12283090
