Not the best for streaming, gaming by itself will be fine, I put a ryzen 5 cooler on a ryzen 3 as its slightly bigger still gets 70c+ while gaming.
(◣_◢) Ryzen 5 3600,   Aorus X370 K7,   XPG 16GB 3200,   Gigabyte 2070 Windforce Corsair RM650x,   LG 32GK650F-B 31.5" 144Hz QHD FreeSync VA,   Kingston 120GB SSD,   Samsung 1TB 860 QVO,   2TB HDD,   Fractal Design Meshify C,   Corsair K63 Wireless,   Corsair Gaming M65 PRO,   Audio Technica ATH M50x,   Windows 10 ProCorsair H100x 240mm.  (◣_◢)
(◣_◢) Ryzen 5 1600,   Noctua NH-L12S,   Gigabyte GTX 1060 6G,   ASUS Prime B350 Plus,   HyperX Fury 8GB DDR4 (2666MHz - 1.3v),   SilverStone ET550-B,   Kingston 120GB SSD 2TB HDD,   Cougar MX330,   Windows 10 Pro.  (◣_◢)
https://linustechtips.com/topic/1031652-ryzen-stock-cooler/#findComment-12281982
Generally, it should be fine. Here's a comparison of the different AMD stock coolers on the 2600. You have the Wraith Stealth.
If you overclock to 4GHz, it may start throttling, but beyond that, you'll be running good temps (Although it may not be quiet).
Fan Comparisons          F@H          PCPartPicker         Analysis of Market Trends (Coming soon? Never? Who knows!)
Designing a mITX case. Working on aluminum prototypes.
Open for intern / part-time. Good at maths, CAD and airflow stuff. Dabbled with Python.
Please fill out this form! It helps a ton! https://linustechtips.com/main/topic/841400-the-poll-to-end-all-polls-poll/
https://linustechtips.com/topic/1031652-ryzen-stock-cooler/#findComment-12281992
In my experience stock coolers have always been worthless unless you have extremely good airflow in your case AND the computer is in a cool room. Come summer, you're screwed and it'll be throttling or shutting down constantly, even at stock speeds with p states or c states or whatever they decide to call them this week to lower speeds at idle.
      __             __
/`'- \'._____\ (_____.'/ -'`\
  '._. :  _|_| |_|_  : ._.'
     ````` /T"Y"T\ `````
https://linustechtips.com/topic/1031652-ryzen-stock-cooler/#findComment-12282002
AMD stock coolers are pretty decent these days.
The Wraith Spire on my wife's Ryzen 5 1600 is cool and decently quiet even with a 3.8ghz OC.
i5-14600KF // 120x38MM Cooler Master AIO // B760i // 64GB DDR5 6000 // PNY RTX 5070 // Cooler Master NCORE 100 Max // Cooler Master V SFX-850 Gold // UWQHD AOC Display
https://linustechtips.com/topic/1031652-ryzen-stock-cooler/#findComment-12282022
Nah not really. My 1600's stock cooler was nearly worthless at stock clocks and couldn't handle any OC whatsoever, even in a cool room. This was with TGK so we're not gonna blame this on the TIM or something.
      __             __
     ````` /T"Y"T\ `````
https://linustechtips.com/topic/1031652-ryzen-stock-cooler/#findComment-12282182
That seems like the exception, not the rule.
https://linustechtips.com/topic/1031652-ryzen-stock-cooler/#findComment-12282188
1 minute ago, violentnumeric said:
Nope.
Dude, pretty much every media outlet agrees with me.
You are either doing it wrong or live in 100f room.
https://linustechtips.com/topic/1031652-ryzen-stock-cooler/#findComment-12282198
8 hours ago, NiiiKK. said:
How good is Ryzen 5 2600 Stock cooler? i plan on gaming and streaming
In decent enviroments with normal load, no OC its OK.
Not the greatest one and they used a 2BB Fan, with a bit Motor Noise but its fine.
"Hell is full of good meanings, but Heaven is full of good works"
https://linustechtips.com/topic/1031652-ryzen-stock-cooler/#findComment-12283323
