I'd just like to know how this build will preform, on This motherboard.
1070 (Not OC)
Ryzen 1700 (Not OC, I don't plan on OC in the future)
2x8 GB
Just want to game at 1080p "the 1070 is overkill for 1080p" and have flexibility for max settings for games such as Mankind Divided
https://linustechtips.com/topic/1031048-mobo-help-again/
2 minutes ago, JoeyStrickGaming said:
@zlolslavez do you think you can link me a mobo that's a good deal, that can get me by with no issues, AM4 socket and DDR4
Hmm those boards are actually a bit more expensive than I thought, but here's a slightly better deal. https://www.ebay.com/itm/MSI-B350-PC-MATE-AM4-AMD-B350-SATA-6Gb-s-USB-3-1-HDMI-ATX-AMD-Motherboard/292930174116?hash=item4433ffbca4:g:spwAAOSwsBtaS5f0:rk:15:pf:0&LH_ItemCondition=4&LH_BIN=1
Current Desktop Build | 2200G | RX 580 4GB | 8GB RAM | CTRL | Logitech G Pro Wireless
Laptop | 2018 MBA 256/16GB | MX Master
https://linustechtips.com/topic/1031048-mobo-help-again/#findComment-12276931
5 minutes ago, zlolslavez said:
Im not sure if this matters to you (OP), but the mobo is 69$ brand new on newegg, easier and safer to shop on!
https://linustechtips.com/topic/1031048-mobo-help-again/#findComment-12276944
