My system has a 2600x with the stock wraith spire cooler. and while I'm playing fortnite and other games my computer will sometimes just freeze. i have realized this is because my CPU is auto overclocking itself to like 4.6 and my temps are skyrocketing. I have no idea how I can stop it from doing this. the method I use now is just using AMD Ryzen master but having to open that and change the settings every time I boot is annoying and sometimes I forget. any help? my mobo is an asrock ab350 pro4 if that helps, idk
https://linustechtips.com/topic/1030271-2600x-auto-overclocking-need-help/
If temps are too high the chip should not be using XMP, what temps are you getting specifically?
Primary PC:
PSU tier list
How many watts do I need?
3 minutes ago, goosequak said:
idling is all over the place, like 45-50. in fortnite its around 60-65
if max temps are 65 then temps are not the issue
Primary PC:
PSU tier list
What tells you your CPU is getting up to 4.6GHz?  I don't that's actually true.
And what settings have you set in Ryzen Master?  Can you show us?
Also, have you changed anything in your BIOS?
AMD Ryzen 5800XFractal Design S36 360 AIO w/6 Corsair SP120L fans  |  Asus Crosshair VII WiFi X470  |  G.SKILL TridentZ 4400CL19 2x8GB @ 3800MHz 14-14-14-14-30  |  EVGA 3080 FTW3 Hybrid  |  Samsung 970 EVO M.2 NVMe 500GB - Boot Drive  |  Samsung 850 EVO SSD 1TB - Game Drive  |  Seagate 1TB HDD - Media Drive  |  EVGA 650 G3 PSU | Thermaltake Core P3 Case
