Wired mesh networking
Go to solution Solved by brwainer,
Making point to point 10Gb connections between computers is feasible for up to three computers - just use dual port NICs or two NICs in each computer, and then each computer directly connects to the other one or two. Beyond that a switch is the most practical solution.
At very large scales, like entire office buildings, we can do “mesh” of the network a few ways. Many people are familiar with LACP or port aggregation between switches, but with the right hardware you can have the different parts of the aggregate connection actually use completely different intermediate switches. A similar thing we can do is combine multiple switches into a single Stack, which allows them to be managed as a single switch with many more ports. The stack connections are much higher speeds, often the fastest ports on the switch, and natively allow a Ring connection. While not as complicated as a mesh on its own, stacks can be combined with LACP and other things to make a very diverse and failure resistant network. Some vendors even allow stacked switches to not be in the same room/closet/IDF.
What do you mean by "wired mesh network"? Mesh networks are exclusively a wireless thing.
¯\_(ツ)_/¯
Desktop:
Intel Core i7-11700K | Noctua NH-D15S chromax.black | ASUS ROG Strix Z590-E Gaming WiFi  | 32 GB G.SKILL TridentZ 3200 MHz | ASUS TUF Gaming RTX 3080 | 1TB Samsung 980 Pro M.2 PCIe 4.0 SSD | 2TB WD Blue M.2 SATA SSD | Seasonic Focus GX-850 Fractal Design Meshify C Windows 10 Pro
Laptop:
HP Omen 15 | AMD Ryzen 7 5800H | 16 GB 3200 MHz | Nvidia RTX 3060 | 1 TB WD Black PCIe 3.0 SSD | 512 GB Micron PCIe 3.0 SSD | Windows 11
https://linustechtips.com/topic/1029800-wired-mesh-networking/#findComment-12265547
5 minutes ago, William D said:
Does anyone know of a way to create a wired mesh network in a home environment?
this?
Image result for tangled ethernet cables
Favorite Threads: PSU Tier List
My Stuff n' Things
The Beast (My Rig)   |CPU: AMD Ryzen 7 7800X3D|  |Cooling: Noctus NHU12S Redux, 6x 120mm Noctua Redux|  |Motherboard:  Asus TUF B650-E WiFi|  |RAM: 4x8gb 6000 Corsair VENGEANCE RGB|  |Graphics Card: EVGA(RIP) GeForce RTX 3070TI FTW3|  |Power Supply: EVGA GT 850W|  |Case: Corsair 4000D Airflow Mid Tower Case(Black)|  |SSD: 1Tb SK Hynix Platinum P41 NVMe, 2Tb Inland Prime NVMe, 500gb Inland 2.5", 4tb WD Blue HDD|  |Monitor: MSI Optix MPG341QR 34" Ultrawide|  |Keyboard: Logitech G815|  |Mouse: Logitech G305|  |Audio Interface: FiiO K7 DAC/Amp|  |Headphones: Sennheiser HD6XX |Webcam: Logitech C920, Logitech C270|
My Network Rack  |Switch: Cisco Dell PowerConnect 5548P|  |Router: Unifi USG|  |Rack: 12U|  |Server: HP Z420|  |Services: Proxmox PVE, Wireguard, Pihole, NVR, NAS|
https://linustechtips.com/topic/1029800-wired-mesh-networking/#findComment-12265552
Well in theory at least I think there should be a way to do them wired by connecting pc's together and using software route the packets the fastest way.
https://linustechtips.com/topic/1029800-wired-mesh-networking/#findComment-12265558
It is possible, but by far the easiest way to do a wired home network would be to buy a gigabit network switch and run cables from there. Most computers don't have the ability to connect to multiple ethernet cables which is a requirement to do what you are suggesting.
¯\_(ツ)_/¯
Desktop:
Laptop:
https://linustechtips.com/topic/1029800-wired-mesh-networking/#findComment-12265572
Sounds like token ring type networks, back in the 10 BASE 2 days of BNC connectors. Those networks aren't really used anymore as they suck.
In terms of topology, most wired networks are mesh networks, or tree, depending on how you look at it.
https://linustechtips.com/topic/1029800-wired-mesh-networking/#findComment-12265578
I am aware and this is my current configuration but I want to upgrade to faster hardware 10gigabit + so mesh networking makes sense to me
https://linustechtips.com/topic/1029800-wired-mesh-networking/#findComment-12265582
Then your best option is probably to buy a used 10 gigabit switch. There are basically no performance benefits to be gained by connecting two computers directly.
¯\_(ツ)_/¯
Desktop:
Laptop:
https://linustechtips.com/topic/1029800-wired-mesh-networking/#findComment-12265606
Looking to buy GTX690, other multi-GPU cards, or single-slot graphics cards:
https://linustechtips.com/topic/1029800-wired-mesh-networking/#findComment-12265667
