This is my current PC build from a few years back: https://es.pcpartpicker.com/list/Bdbgjy
I mostly use the PC for gaming and youtube/netflix. i wanna be able to play the upcoming metro exodus and anthem at decent settings and with this upgrade i wouldn't need to upgrade for atleast a few years. Im currently looking at getting the i5 8600k and the rtx 2060. What are your recommendations?
My budget for upgrading is $1200.
Thanks in advance
https://linustechtips.com/topic/1029713-pc-upgrade-please-help/
Try and find a used i7 4770K or 4790K on Ebay.
زندگی از چراغ
Intel Core i7 7800X 6C/12T (4.5GHz), Corsair H150i Pro RGB (360mm), Asus Prime X299-A, Corsair Vengeance LPX 32GB (4X4GB & 2X8GB 3000MHz DDR4), MSI GeForce GTX 1070 Gaming X 8G (2.113GHz core & 9.104GHz memory), 1 Samsung 970 Evo Plus 1TB NVMe M.2, 1 Samsung 850 Pro 256GB SSD, 1 Samsung 850 Evo 500GB SSD, 1 WD Red 1TB mechanical drive, Corsair RM750X 80+ Gold fully modular PSU, Corsair Obsidian 750D full tower case, Corsair Glaive RGB mouse, Corsair K70 RGB MK.2 (Cherry MX Red) keyboard, Asus VN247HA (1920x1080 60Hz 16:9), Audio Technica ATH-M20x headphones & Windows 10 Home 64 bit.
The time Linus replied to me on one of my threads:
https://linustechtips.com/topic/1029713-pc-upgrade-please-help/#findComment-12264717
Thanks in advance
if you decide to upgrade then just wait for the new ryzen chips that are rumoured to be better than intel cpus in gaming
gaming system: Intel core I9 12900ks / biostar Z690A valkyrie / 4x8gb corsair Vengeance @3333Mhz ram / RX 7900XTX pulse gpu / Thermalright peerless assassin 140 /Coolermaster Qube 500 case / Be Quiet Dark Power Pro 12 1500w power supply
laptop: Dell xps 9510, 3.5k OLED, i7 11800h, rtx 3050 ti, 2x16gb DDR4 @ 3200Mhz, 1TB main drive, 2TB add in ssd
https://linustechtips.com/topic/1029713-pc-upgrade-please-help/#findComment-12264720
an i7 and a 1080 would be awesome
Primary PC:
PSU tier list
How many watts do I need?
https://linustechtips.com/topic/1029713-pc-upgrade-please-help/#findComment-12264724
if you wanna do the new build from the ground up -
little over, but you get a 6c/12t with Overclocking, a very solid board, you keep your storage, and an RTX 2070.
Rig 1: i7-9700k OC'd to 5.0ghz all core | EVGA XC RTX 2080Ti | ADATA DDR4 2400mhz 4x8gb | ASUS PRIME Z370-P | Asetek 550LC 120mm | ADATA 480GB SSD & Toshiba P300 3TB | Cooler Master Masterbox MB500 | Win 10 Home | Logitech G910 Orion Spectrum, G502 Proteus Spectrum, G933 Artemis Spectrum Snow Wireless Limited Edition, Corsair MM300 Mouse Pad | 2 MSI Optix Curved 27" FHD Monitors
(before i sold the WD drive and MSI gpu - https://www.userbenchmark.com/UserRun/11946219 171 gaming. felt good.)
Rig 2: i7-7700k Stock clocks | MSI Armor GTX 1070 | ADATA DDR4 2400mhz 2x8GB | MSI Z270 A-Pro | WD Green 240GB SSD & 2TB Seagate HDD | Thermaltake Core G21 Tempered Glass Edition | Win 10 Home | 2 HP Omen FHD 144hz 24.5" Monitors
Rig 3: i7-6700 | GT 730 & GT 645 OEM | Some random DDR4 2133mhz 2x8gb sticks | OEM Dell Mobo | WD Black 2TB HDD & Toshiba 1TB HDD | Win 10 Home | 3 27" Dell FHD Monitors
Rig 4: i7-4770 | EVGA SSC 1050ti | Some random DDR3 ram 2x2gb and 2x4gb sticks | OEM Dell Mobo | Stock Cooler | 1TB WD Black HDD | Win 7 Home
RIP
Rig 5 (dead and dismantled and sold) : i7-7820X OC'd to 4.8ghz all core | MSI DUKE 1080ti | ADATA DDR4 2400mhz 4x8gb | Gigabyte X299 UD4 PRO | Asetek 240mm AIO | WD Green 240gb SSD | Other various components that I can't remember
Rig 6 (same fate as rig 5) i7-8700k stock clocks | MSI DUKE 1080ti | ADATA DDR4 2400mhz 2x8gb | MSI Z370 A-Pro | Asetek 550LC 120mm | WD Green 240GB SSD & Toshiba 2TB HDD | Other various components that I can't Remember
https://linustechtips.com/topic/1029713-pc-upgrade-please-help/#findComment-12264727
14 minutes ago, billpulsar said:
wouldnt these CPUs bottleneck a newer gpu?
No, they shouldn't do.
زندگی از چراغ
https://linustechtips.com/topic/1029713-pc-upgrade-please-help/#findComment-12264974
