I started another thread and got given good suggestions but I was also thinking of an rgb build with a black case which will a tempered glass. My budget would be £1000 I’m ok with spending £1100 or close to that. I would only do gaming on there and some studies. For gaming I would get a 144hz monitor and play games like overwatch, csgo, r6, outlast, gta etc. So I would want the pc to at least get 144 fps or more. The budget wouldnt include a monitor, mouse or keyboard just the pc.
https://linustechtips.com/topic/1029393-rgb-build-help/
What resolution are you playing at ?
Asus Sabertooth x79 / 4930k @ 4500 @ 1.408v / Gigabyte WF 2080 RTX / Corsair VG 64GB @ 1866 & AX1600i & H115i Pro @ 2x Noctua NF-A14 / Carbide 330r Blackout
Scarlett 2i2 Audio Interface / KRK Rokits 10" / Sennheiser HD 650 / Logitech G Pro Wireless Mouse & G915 Linear & G935 & C920 / SL 88 Grand / Cakewalk / NF-A14 Int P12 Ex
AOC 40" 4k Curved / LG 55" OLED C9 120hz / LaCie Porsche Design 2TB & 500GB / Samsung 950 Pro 500GB / 850 Pro 500GB / Crucial m4 500GB / Asus M.2 Card
https://linustechtips.com/topic/1029393-rgb-build-help/#findComment-12261987
Please fill in your signature so we can help you better.
https://linustechtips.com/topic/1029393-rgb-build-help/#findComment-12261993
1 minute ago, Tevildo said:
1080p and what do you mean by signature?
If you click on your name up top you get a list, go to account settings, then go to signature and fill it in so we know what parts you have and what not.
https://linustechtips.com/topic/1029393-rgb-build-help/#findComment-12262003
So you want a video card and monitor ?  If you want 144fps then grab a 1070ti or a 2060 or 2070 if the price difference isn't that much.  I have no idea what monitor you have or want or what your CPU is your GPU,, please fill in signature as I said above so we can help you better.
https://linustechtips.com/topic/1029393-rgb-build-help/#findComment-12262012
https://linustechtips.com/topic/1029393-rgb-build-help/#findComment-12262081
