Help bricked mi a2
Go to solution Solved by hammad1029,
got it warrantied and they told me that they used the testpoint edl method to fix the phone. Thanks anyways
I was trying to install stock rom on the MI A2 after installing RR rom. MiFlash said "flashing is not allowed for critical partitions" and when i did "fastboot flashing unlock_critical" from cmd i got "remote: Flashing Unlock is not allowed". I then used the allinone tool from xda and pressed "lock loader" to unlock it again and ended up bricking the device as it now shows "your device is corrupt. it can't e trusted and will not boot" I can't enter recovery either only fastoot and nothing works. PLEASE HELP FAST
https://linustechtips.com/topic/1029171-help-bricked-mi-a2/
On 2/3/2019 at 12:15 PM, SpiralTTGL said:
there is no helping if it doesn't enter recovery its dead in the water
Umm....Wrong - when I was installing MIUI on my A2, the usb cable moved and lost connection thus bricking the phone. I could not even enter fastboot or recovery. The way to fix this is open up the phone and use the test points to enter EDL or whatever was that download mode called. That way I successfully brought my phone back to life
CPU: AMD R7 5800x | GPU: XFX 5500XT 4GB | RAM: 2x8GB Kingston Fury Renegade 3600MHz CL16 | Cooling: Deepcool Gammaxx L360 | MB: Aorus B550 Elite V2 | Storage: Samsung 850 Evo 250gb & WD20EAZX | Case: Antec DF700
Lenovo ThinkPad Yoga 460: Intel 6200U | 8GB | 256GB SSD | Active pen
https://linustechtips.com/topic/1029171-help-bricked-mi-a2/#findComment-12265316
