VM system build
Go to solution Solved by Brucethehunter,
Well one system running a VM would be ideal for space I'm not opposed to using 2 systems price I'm flexible on but would like to keep it as cheap as possible cause I'm in the Caribbean and I'm going to end up paying almost double for anything, I wouldn't mind using slightly older parts or even sever parts on the VM cause it might be always on
Hey guys this is bruce, so I'm thinking about building a 2 vm tower but I'm under sure what parts to use and what can be used with what, ideally I want machine 1 to be mostly for work Microsoft office stuff no video editing or anything crazy like that lol  and light gaming like emulators with LoL being the heaviest thing their and machine 2 to be for streaming and heavy gaming but I'm fine with 1080p being the max as I don't want to spend a exorbitant amount on this. The only parts I have so far is peripherals and a bunch of hhd's.
https://linustechtips.com/topic/1028615-vm-system-build/
https://linustechtips.com/topic/1028615-vm-system-build/#findComment-12256186
Something along the lines of a r7 1700 with a rx 570 and then a hd 7950 from the used market.
Sorry for late responce
https://linustechtips.com/topic/1028615-vm-system-build/#findComment-12257255
