I have an AMD FX-6100 (I know I may need an upgrade soon) clocked at 4.0 Ghz @ 1.3125 Volts and I am getting 54C in AIDA64 but when I run Cinebench I get 63C.
Can anyone explain me why is there such a big difference? Also, what do you think is more accurate as a thermal test?
Thanks in advance!
CPU: AMD FX-6100 Black Edition @3.9GHz GPU: XFX 7970 DD (1062/1520 MHz) MOBO: ASUS Sabertooth 990FXA(1st Revision) RAM: Corsair Vengeance 16GB @ 1333MHz Storage: Corsair Force 3 120GB(Boot) + WD Green 1TB(storage) PSU: FSP AURUM 600W(80+ Gold) CPU Cooler: Cryorig M9a  Case: NZXT Tempst 410 Elite(Mid-Tower) Mouse: Logitech G602(Manufacturer Refurbished) Keyboard: Noppoo Choc Mini(Cherry MX Blue) AUDIO:Sennheiser HD 598+ASUS Xonar DGX Monitor: LG M2280DF 21.5" 1080p(TN-75Hz)
https://linustechtips.com/topic/1028434-temperature-question/
Different stress testing algorithms. The most accurate test is just doing what you're going to be doing with the CPU, the stability in stress tests really doesn't matter to be honest. I've had plenty of CPUs that were fine for many hours in stress testing, only to crash frequently in games, and some that would crash in stress testing but were perfectly fine in games.
      __             __
/`'- \'._____\ (_____.'/ -'`\
  '._. :  _|_| |_|_  : ._.'
     ````` /T"Y"T\ `````
https://linustechtips.com/topic/1028434-temperature-question/#findComment-12254147
