I have a mp4 file that is 1920x1080p. If I play this video on a 4K screen it is blurry. I searched online and found out 4K up scaling and converting is useless. Then I realized I can just play the footage on a 1080p screen and use a separate camera to record it in 4K. My question is will it actually display on my 4K tv and look the same as the 1080p tv if I do this. Thank you.
https://linustechtips.com/topic/1028370-need-help/
Sounds like you don't NEED HELP!!! and you can just find out yourself by recording a sample, unless you actually can't and need help to do so.
Primary PC:
PSU tier list
How many watts do I need?
https://linustechtips.com/topic/1028370-need-help/#findComment-12253639
You have a 1080p file.
You're dissatisfied with the cleanliness of the footage.
You've determined that upscaling the footage is "useless"/not providing the sharpness/detail increase that you wanted.
You want a more detailed file.
You need to obtain some version of this file with more detail. We don't know the type of content, so whether it's higher bitrate, a higher resolution, or some combination of the two that does the trick for you is anybody's guess.
Refilming footage playback on a higher resolution camera is absolutely not going to somehow "invent" more detail for you, it's going to introduce even more noise into the images.
The *closest* we can get is the use of clever algorithms to upscale the footage, but you've already nixed that.
https://linustechtips.com/topic/1028370-need-help/#findComment-12253984
