i seen them conectors on the wifi cards inside ols sky plus boxes u could just sit them on a usb header
#1:- STRIX X470-F GAMING | Ryzen 7 2700X @ 42.50mhZ | Patriot Viper Steel Series 16gb (2x8) 4000 MHz | MSI RTX 2080 GAMING TRIO | ASUS ROG RYUJIN 240 | NZXT S340 ELITE | 2X 1TB 970 EVO PLUS M.2  +  3 X 1TB FIRECUDA 2.5" HYBRID DRIVES | EVGA SUPER NOVA G3 80+GOLD 1000W | AND ENOUGH RGB TO MAKE YOUR EYES MELT
#2:- GIGABYTE X470 AORUS ULTRA GAMING | RYZEN 2700X | AURUS 3200MHz | MSI GTX 1060 6GB | CIT BLAZE MID RED-BLACK | STOCK RYZEN RGB AIR COOLER | 2TB WD HDD + 500GB 970 EVO PLUS
#3:- STRIX X470-F GAMING | Ryzen 7 1800X | DOMINATOR LPX 3000MHz | STRIX 970| COOLER MASTER 240 ML | GAME MAX AURORA MID TOWER | CRUCIAL P1 1TB SSD M.2 + FIRECUDA 1TB HYBRID DRIVE
https://linustechtips.com/topic/1027485-weird-led/#findComment-12246351
2 hours ago, repeterbr said:
Hey guys, i had a problem with my old PC  and i manage to save some old pieces. found this LED but i have never seen a 5-pin connector before, is there any adapter to this ting?
As James said that is a JST connector however for making that board work you will need to trace each pin and determine it's probable use and what it's for as that board is not just an LED strip but has some power regulation and was supposedly designed for some kind of control protocol.
https://linustechtips.com/topic/1027485-weird-led/#findComment-12246377
