Currently I have a decent budget system the specs are as follows:
  • Intel Core i5-2500
  • HP Z210 Workstation Motherboard
  • 10GB DDR3 Memory @ 1333MHz
  • Gigabyte Windforce R9 290X 4GB OC
  • ADATA 256 GB SSD
  • 1TB Western Digital HDD
  • 600W EVGA PSU
  • Fractal Design Meshify C TG
I am selling my entire system except for my drives and graphics card to a friend next week for $400.  With this in mind I would like an upgrade even if it is only a few percent and upgrade is an upgrade to me. I already choose to buy the same case again because I love it and it's cheaper now so whatever.  I also want a better power supply with nice cables so I was thinking this one.
If I buy this case and power supply that will leave me with $250 USD to spend on a processor, motherboard, and memory.  I was thinking an older 6 core Xeon and 16GB of DDR3 might be doable but I would like to hear what other have to say on the topic.
I should also mention that I game at 4K.  (My system seems underpowered for 4K and to be honest it is a little bit but I am able to play GTA V at 4K all high except textures and shadows which are set to very high at over 60 FPS.)
Parts I have already decided on 100%:
https://pcpartpicker.com/list/V3rv4q
Thanks in advanced.
https://linustechtips.com/topic/1027371-help-upgrading-my-current-system/
Type Item Price
CPU AMD - Ryzen 3 2200G 3.5 GHz Quad-Core Processor $94.99 @ Amazon
Motherboard ASRock - B450 Pro4 ATX AM4 Motherboard $69.89 @ OutletPC
Memory G.Skill - Ripjaws V Series 8 GB (2 x 4 GB) DDR4-2400 Memory $59.89 @ OutletPC
  Prices include shipping, taxes, rebates, and discounts
  Total (before mail-in rebates) $244.77
  Mail-in rebates -$20.00
  Total $224.77
  Generated by PCPartPicker 2019-01-29 15:30 EST-0500
Here's a list of brand new parts for under $250. the PSU you picked out should be decent enough. You could go used, but if you stick with DDR3 you're only going to have to spend more on upgrades later. If you get DDR4 now, you can just reuse it later on.
You could get 2x8 RAM instead of 2x4, but it will be more expensive. You definitely want dual channel though, Ryzen benefits from it (but its typically better all around anyways).
You could also get a Ryzen 5 2400G instead of the 2200G, which is also more expensive; but it is a better CPU and it might keep you from having to upgrade as quickly. But, the CPU bottleneck (especially with your current GPU) will be much less at 4k.
The motherboard isn't amazing, but it should be decent for your budget.
On a R9 290 you aren't going to last much longer on decent settings at 4k. I'd definitely look into getting a better GPU relatively soon (late summer maybe).
Primary PC: - https://pcpartpicker.com/list/8G3tXv (Windows 10 Home)
HTPC: - https://pcpartpicker.com/list/KdBb4n (Windows 10 Home)
Server: Dell Precision T7500 - Dual Xeon X5660's, 44GB ECC DDR3, Dell Nvidia GTX 645 (Windows Server 2019 Standard)
*SLI Rig* - i7-920, MSI-X58 Platinum SLI, 12GB DDR3, Dual EVGA GTX 260 Core 216 in SLI - https://pcpartpicker.com/list/GHw6vW (Windows 7 Pro)
HP DC7900 - Core 2 Duo E8400, 4GB DDR2, Nvidia GeForce 8600 GT (Windows Vista)
Compaq Presario 5000 - Pentium 4 1.7Ghz, 1.7GB SDR, PowerColor Radeon 9600 Pro (Windows XP x86 Pro)
Compaq Presario 8772 - Pentium MMX 200Mhz, 48MB PC66, 6GB Quantum HDD, "8GB" HP SATA SSD adapted to IDE (Windows 98 SE)
Asus M32AD - Intel i3-4170, 8GB DDR3, 250GB Seagate 2.5" HDD (converting to SSD soon), EVGA GeForce GTS 250, OEM 350W PSU (Windows 10 Core)
*Haswell Tower* https://pcpartpicker.com/list/3vw6vW (Windows 10 Home)
*ITX Box* - https://pcpartpicker.com/list/r36s6R (Windows 10 Education)
Dell Dimension XPS B800 - Pentium 3 800Mhz, RDRAM
In progress projects:
*Skylake Tower* - Pentium G4400, Asus H110
*Trash Can* - AMD A4-6300
*GPU Test Bench*
*Pfsense router* - Pentium G3220, Asrock H97m Pro A4, 4GB DDR3
Good luck finding a good board for it. Server boards are clunky to use, consumer boards you can still buy are either made by Chinese or even South East Asian factories that break apart broken boards and scavenging functioning parts to make a "new" one of their own (which means no quality assurance or control to speak of), or just very expensive.
I'd say no on that ancient PSU design, no point to buy it in 2019. I know I'm also using an old PSU, but I got that at about the same time as the CPU came out from Intel's fab.
Desktop benching:
