Hello,
I have a CPU case "Thermaltake Versa H18 Window Micro Case "
https://www.thermaltake.com/Chassis/Micro_Case_/Versa/C_00003148/Versa_H18_/Specification.htm
CPU cooler height limitation: 155mm  (Check Specs)
And I am concerned if it these CPU air coolers will fit?
1) GAMMAXX GT TGA - http://www.deepcool.com/product/cpucooler/2018-06/7_8610.shtml
Overall Dimension 135X84.8X156 mm
2) GAMMAXX GT - http://www.deepcool.com/product/cpucooler/2017-06/7_6732.shtml
I know it's just 1 mm more, but will it close?
Thanks!
CPU: Intel i5-8400 (8th gen) | Motherboard: Gigabyte Z-370M DS3H | RAM: 2 x 8GB 3000 MHz Trident Z RGB | GPU: Gigabyte RTX 2060 6GB | PSU: Seasonic FOCUS+ Gold 550W | Case: Thermaltake Versa H18 TG Edition| Cooler: DeepCool Gammaxx GT RGB CPU Cooler | Storage: SSD - Kingston 120GB / HDD - Toshiba 1TB | Monitor: 24" HKC 144Hz | OS: Windows 10 64-bit
https://linustechtips.com/topic/1027300-will-it-actually-fit/
Assuming the Window is plastic, you could force it to fit. If it's glass, don't. Over-tightening the cooler would possibly also help but you run the risk of destroying both the CPU silicon and motherboard pins.
PLEASE QUOTE ME IF YOU ARE REPLYING TO ME
Desktop Build: Ryzen 7 2700X @ 4.0GHz, AsRock Fatal1ty X370 Professional Gaming, 48GB Corsair DDR4 @ 3000MHz, RX5700 XT 8GB Sapphire Nitro+, Benq XL2730 1440p 144Hz FS
42U Server Rack: ISP Modem + UDM-SE + APC 3kVA UPS + 3x Dell Precision 5820 + TBD
Retro Build: Intel Pentium III @ 500 MHz, Dell Optiplex G1 Full AT Tower, 768MB SDRAM @ 133MHz, Integrated Graphics, Generic 1024x768 60Hz Monitor
https://linustechtips.com/topic/1027300-will-it-actually-fit/#findComment-12244746
1mm is fine, even if TT didnt leave any margin of error, just don't tighten the side panel all the way in. 1mm isnt going to make the side fall off.
No it doesnt, CPUs have lids specifically to avoid people cracking dies when installing coolers so they can use more mounting pressure (the same can't be said for laptop CPUs and all GPUs, SOCs). The pins are at a length such that the PCB of the CPU will take all the extra force and spread it to the board but not the pins.
Desktop benching:
https://linustechtips.com/topic/1027300-will-it-actually-fit/#findComment-12244765
Thanks so much guys! :)
https://linustechtips.com/topic/1027300-will-it-actually-fit/#findComment-12244772
Pretty sure this applies to TIM only, not soldered IHS.
https://linustechtips.com/topic/1027300-will-it-actually-fit/#findComment-12244895
soldered IHS are pressed onto the PCB when the solder is still relatively soft, so the lid still contacts the PCB and spreads the pressure over. So many people used soldered Sandy Bridge CPUs and back then no one broke their CPUs because of it. Havent heard of Ryzens or FX or Phenoms getting damaged by mounting pressure either.
Desktop benching:
https://linustechtips.com/topic/1027300-will-it-actually-fit/#findComment-12245069
TIL.
https://linustechtips.com/topic/1027300-will-it-actually-fit/#findComment-12245077
  • 2 years later...
Sorry for being a kind of necromancer, but the topic was on the first page when I googled the same question that OP had, so I feel sorta obliged to inform future searchers that it fits well. To be exact, in my case it was GAMMAXX GT TGA (135x84.8x156mm). After installing it, the window was still a full millimeter or two away, so the window didn't even touch the cooler when I was opening and closing the case.
https://linustechtips.com/topic/1027300-will-it-actually-fit/#findComment-14749121
