is there a small audio mixer that can take 2 inputs (one 3.5mm + one 3.5mm or SPDIF optical) and has at least one (preferably two) 3.5mm outputs for the mixed sound, but also has a 3.5mm output as a direct passthrough for at least 1 of the original sources?
If anyone has ever seen anything like this or has used anything like this it would be helpful.
Thanks! ?
My RIG:
I7 6700k - GTX 1080 -  32GB Ram - 256GB 950 Pro(boot) + 1TB 850 EVO(Programs) + 4TB 860 EVO(Games) + 1TB WD Black (Files)
https://linustechtips.com/topic/1026685-audio-mixer-help/
Thanks! ?
Is it like this??? What in the world do you intend to do?
Lol, only audio related thing I'm doing is burning cd's for my car, cause no AUX or Bluetooth. (1996 Camaro) and I want it stock as possible.
But I have used something like, a pass through of the front input ports of my case, and went through the mother board via the mixer. (Found this randomly messing with my speakers and my yeti with my headset plugged into it)
CPU i7-7700k 5.5GHz Delidded GPU MSI 1060 6GB ARMOR OCV1 +335/+1000 RAM 16GB 2x8 Corsair Vengeance WLED 2400/3000 C14 COOLER Corsair H100i v1 BOARD MSI Z270 SLI SSD Samsung 960 Evo 250G, x3 2T Samsung 860 Evo HDD WDB 4T, WDB 1T PSU EVGA 650GQ80+M CASE Cougar PanzerS
CPU i7-10700k GPU MSI RTX 2080 Duke POS RAM 32GB 2x16 Corsair Dominator Platinum RGB 3200/3600 CL14 COOLER CM MasterLiquid ML360R RGB Push/Pull BOARD MSI MEG Z490 Ace SSD 980 Pro 500G, 860 Evo 1T PSU EVGA 1000P2 CASE Phanteks Enthoo Luxe TG Black
CPU Pentium G4600 GPU MSI GTX 1080 Armor OCV1 +100/+400 RAM 8GB 2x4 G.SKILL Aegis 2133/3000 CL16 COOLER Corsair H100i v1 BOARD MSI H110M Pro-VD-Plus SSD 860 Evo 1T HDD WDB 500G, WDB 1T PSU EVGA 430W Bronze CASE Deepcool Tesseract/ VIVO
SERVERS i5-3470, i5-3470, i5-4590 GPUS MSI 750Ti 4GB, BFG GTS 250 1GB, GTX 690 RAMS 3x 16GB 2x8 1866 C8 PSUS 2x EVGA 1000T2 COOLERS Stock, Stock, Custom Loop BOARDS Intel, Intel, EVGA Classified SSD x3 860 250G HDDS I don't care to list CASES Optiplex, Optiplex, 2000s Water Case
560HP/607TQ E85 198MPH2000 Audi S4 2.7Bi-Turbo with K04/RS6 Inlets SRM -  DAZ Tune - 2.8L N/A DOHC Heads  -APB Block - Mahle Pistions - JHM Racing H-beam Rods - TheTuner Manifolds - 3.5in to 3in Exhaust with Magnaflow Dual Box - Dual Titanium Exhaust Tips - SAI CNC Delete - S4 Modified Airbox - 85MM Maf- RS4 Intake Manifold p&p RS4 Y-pipe - RS4 Bi-pipes - RS4 Fuel Rail - A8 TTB - Billet Divertervalves - Silicone Hose Everything - SRMv4 Intercoolers - Clutch Fan Delete/Block off - Power Steering Light Pully - FluidAmper - Billet Cam gears - V8 Cam Bolts - ABS Relocate - VW Diesel Oil Pump
https://linustechtips.com/topic/1026685-audio-mixer-help/#findComment-12239250
Like what? Link? as for what I'm doing with it....well that's a bit of a bit long to explain, there are other ways to do what I want but if i could find a product like this it would make life a lot simpler and severely reduce the amount of cords I needed.
My RIG:
https://linustechtips.com/topic/1026685-audio-mixer-help/#findComment-12239300
Here this image sort of shows why even though there are other ways to do this it would be cleaner and easier if something like this existed, and why im looking for it.
My RIG:
https://linustechtips.com/topic/1026685-audio-mixer-help/#findComment-12239355
Sorry, got side tracked, and forgot to post the link (hehehe) https://www.dr-lex.be/hardware/hdar_review.html
Also this thing has lots of products they are talking about, sorry that I do not have time to search it right now tho.
https://www.ecoustics.com/electronics/forum/accessories/1656.html
Edited by Crazycatman
More links
https://linustechtips.com/topic/1026685-audio-mixer-help/#findComment-12243270
