Quick-Switch For Playback Device?
Hi, so I'm wondering if there's an application or macro out there that allows me to switch between my headphones and my monitor's speakers.
It gets slightly tedious having to go all the way down to the bottom, open up playback devices, and switch when I want to.
Is there a way I can press a button to switch between the two playback devices?
mechanical keyboard switches aficionado & hi-fi audio enthusiast
switch reviews  how i lube mx-style keyboard switches
https://linustechtips.com/topic/1026118-quick-switch-for-playback-device/
I don't think there's an option for that in Windows but, I found this: Link
If you can figure out how to make a macro, it seems like it should do the trick.
Quote from there:
Quote
I found a solution! It took a lot of work and I still prefer SoundSwitch but nonetheless this works:
Download AutoHotKey (v 1.1) link: http://www.autohotkey.com/
Then things get tricky, you have to script it yourself. It took me a while but I finally made my own (with the help of the internet)
Note: Make sure AutoHotKey is installed in Program Data/Microsoft/Windows/Start Menu/Programs
(Program Data is a hidden file, you will have to enable hidden files to be shown)
After that is done go to the desktop and right click
Go to new
Then you should see Auto HotKey Script as an option, click on that
(if you don't see that you make sure AHK is in Program Data/Microsoft/Windows/Start Menu/Programs)
Once you've placed a new script name it what you want (I named it Playback Device Switch)
Right click, then click on edit script
CTRL+A then backspace will delete all the default script in it
Then copy and paste my script as seen below:
^!F11::
    Run, mmsys.cpl
    WinWait,Sound
    ControlSend,SysListView321,{Down 2}
    ControlClick,&Set Default
    ControlClick,OK
    return
^!F12::
    Run, mmsys.cpl
    WinWait,Sound
    ControlSend,SysListView321,{Down}
    ControlClick,OK
    return
Note: ^ is CTRL and ! is ALT
With this setup CTRL+ALT+F12 will select your first device (Speakers in my case)
CTRL+ALT+F11 will select the 2nd device (Headphones for me)
I would disable any devices that you won't be using, that way you will only have 2. If you want more (for other devices) just follow that pattern like this
Hotkey ::
   Run,mmsys.cpl
   WinWait,Sound
  ControlSend,SysListView321,{Down 3 (or whatever # you need it to be)}
  ControlClick,OK
  return
Let me know if you have any questions!
3
I tried the suggested script but, for me, all it does is open mmsys.cpl which, is a good start but, seems like you'd need to configure some button presses.
Something like: (Open mmsys.cpl - Press Up - Press tab 3 times - hit enter) would work in my case but, I have no idea how could that be set up.
Make sure to quote or tag people, so they get notified.
