okay i build a pc on 12th jan 2019 and its specs are
ram-8gb corsair vengence
gpu -zotac rtx 2070 blower edition
mobo-x370 motherboard(with updated bios)
cpu-ryzen 2600
chiptronix psu 650 watt 80+ bronze certified
now yesterday i changed this to cooler master 600watt
now i build the pc on 12 th of jan it was running smooth till 18th january but in the morning of 19th jan
when i started it so gpu fans are running high and  there is no display so i figure out that there is psu problem
well i changed it and guess what it worked .but agian when i shut it at night and check this morning there is same problem.
gpu fan is running high.over night how it could happend and no i didn't done anything like oc or xmp.
now i am not able to figure it out what is happening  i mean two psu are not able to deliver  the power.
is there something wrong with motherboard. or gpu
or the ups i am using.
please help its too much important
https://linustechtips.com/topic/1025662-new-build-problem/
If you pull out the GPU and try to start it with integrated graphics (or just another GPU if you don't have integrated graphics and have one sitting around somewhere or can ask a friend), what happens?
edit: yeah you don't have integrated graphics so you'll either need to grab an old GPU or ask someone you know to let you borrow their card for testing.
Specs: CPU: AMD Ryzen R7 3700X @4.4Ghz, GPU: Gigabyte RX 5700 XT, RAM: 32 GB (2x 8GB Trident Z Royal + 2x 8GB TForce Vulkan Z) @3000Mhz, Motherboard: ASRock B550m Steel Legend, Storage: 1x WD Black 1Tb NVMe (boot) + 1x Samsung 860 QVO 1Tb SSD (storage), Case: Thermaltake Core V21, Cooler: Noctua NH-D15
https://linustechtips.com/topic/1025662-new-build-problem/#findComment-12230508
8 hours ago, Arc23 said:
well man my gpu is running but each time the new psu i put that goes dead
Probably your motherboard, is it the proper wattage?
✧・゚: *✧・゚:*  Quote for a reply  *:・゚✧*:・゚✧
✧・゚: *✧・゚:*   Ask for discord   *:・゚✧*:・゚✧
https://linustechtips.com/topic/1025662-new-build-problem/#findComment-12232153
2 hours ago, Arc23 said:
because i am able to start it with one trick i have to remove my cmos battery and wait for like hour and put it back and then start it work but when you shut down next time it won't post i have to do same thing.
RMA time
Primary PC:
PSU tier list
How many watts do I need?
https://linustechtips.com/topic/1025662-new-build-problem/#findComment-12233221
