I am currently building my dream build after giving my ryzen 5 2600 system with a gtx 1060 to my brother and also using that as a streaming pc. We share 7 monitors on 1 desk I have a i9 9900k with asus z390 mobo and 16gb of ram anyway I’m wondering if I should do 2 1070s or 1080s in SLI in order to connect 7 monitors to my new pc or if I should do a 2070 and a 1060 using 2070 for my 4 144hz monitors and 1060 for 3 75hz monitors. Thoughts?
https://linustechtips.com/topic/1025139-need-help/
3 minutes ago, emosun said:
anything that can output at least 4 signals on one and 3 on the other so two 1060's or higher would be required from that series
Thank you so much I’m most likely  going to go a 2070 for gaming displays and get a 1060 for multitasking displays! LTT is a blessing!
https://linustechtips.com/topic/1025139-need-help/#findComment-12225715
