Can someone give me a full list of what PC parts and specs I would buy to be used for Sketchup and VRay rendering. I have already an i7-7700 cpu, GTX 1080 and a 32 GB ram but still it takes around 30 mins to 1 hr to render 1 scene. I think the intel xeon and nvidia quadro would give me a faster rendering time for vray? Need help thanks.
https://linustechtips.com/topic/1024810-need-help-urgent-t_t/
GPU not important, AFAIK you are already at a decent GPU tier for CUDA/OpenCL rendering.  2080 is maybe a 30% bump and 2080 Ti may be good for 50%.
CPU OTOH, get a Threadripper 2950x or 2990wx.  ~4x performance on the 2950x and ~8x the performance on the 2990wx.
https://linustechtips.com/topic/1024810-need-help-urgent-t_t/#findComment-12222477
Are you using Vray RT or Vray?
Vray RT uses the GPU, where normal Vray only uses the CPU. Also, overclocking helps.
For CPU rendering, the threadripper 2 would render without issue.
As for GPUs, Vray RT only really cares about CUDA cores (Unless your scene is so large it exceeds the vram size)
https://linustechtips.com/topic/1024810-need-help-urgent-t_t/#findComment-12222587
