Two computers + Two monitors HELP
Alright gentlemen.
To make matters simple, here's a graphic to show my setup:
So here's my problem:
I can't seem to get an image from the Mac to display on the ASUS monitor.
The Mac only has one HDMI port. But it also has 6 thunderbolt ports which can also accept miniDisplayPort connections and will work with monitors.
The PC has a GTX 1080Ti with 2+ DisplayPort outputs.
Now, I've connected this mac to this ASUS monitor in two ways:
- MiniDisplayPort to HDMI adapter (SEE IT HERE)
- MiniDisplayPort to Displayport cable
Both ways worked when I was using the ASUS monitor as a single display for the mac.
And then I added the LG, as per the connections in my diagram and it STILL worked.
Until yesterday.
For some reason, now I can't get the ASUS to show an image from the Mac unless I use the ASUS' DisplayPort port.
HDMI just doesn't wanna work anymore.
This is important because I game on the PC so I need the 100Hz to work on that side.
I don't need that on the Mac since I only use the mac for editing video and audio.
The other thing is, everytime I want to switch machines I have to switch the inputs on both monitors. This sucks. There has to be a better way to like press ONE button and switch over without having to reach for the buttons on the monitors.
I already have to swap keyboard and mouse which is enough of a pain...
The whole reason I have to do all this, is because I don't have space here to have two desks.
HELP.
I am one with the Force, and the Force is with me.
https://linustechtips.com/topic/1024321-two-computers-two-monitors-help/
