https://linustechtips.com/topic/1023775-first-pc-build/
Looks nice, glad you didn't go for the MSI armor card that so many have fallen for.
What refresh rate is your monitor?
Primary PC:
PSU tier list
How many watts do I need?
https://linustechtips.com/topic/1023775-first-pc-build/#findComment-12213148
1 minute ago, TMFN_WOLF said:
60
Then this is a good build for that.
Primary PC:
PSU tier list
https://linustechtips.com/topic/1023775-first-pc-build/#findComment-12213165
good build.
for ssd get a samsung or crucial (micron).
Crucial MX500 is a good balance of price to perfomance.
The RX580 is dropping prices, brand new from $189
https://www.newegg.com/Product/Product.aspx?Item=N82E16814131713R&Description=rx580&cm_re=rx580-_-14-131-713R-_-Product
https://linustechtips.com/topic/1023775-first-pc-build/#findComment-12213190
2 hours ago, xKyric said:
Looks great.
Will 240GBs of storage be enough for you?
I built a similar rig to this back in October, on an Asus X470 board, using a Radeon RX580, and an ADATA 240GB NVMe M.2 PCIe x 4 drive. The operating system and all the progs, etc, easily fit onto the 240GB drive with over 100GBs to spare. I have a 500GB drive and a 6TB HDD attached for if I need any more space.
Don't do anything that I wouldn't do. - But if you do; don't get caught!
https://linustechtips.com/topic/1023775-first-pc-build/#findComment-12214368
