My monitor is acting weird
Kohtalox
I recently bought an Asus ROG Swift PG258Q 240Hz monitor, and it has been working fine, until today. Today there has been a couple occasions where the screen would start flicking between showing an image and a black screen, at the same time it the power light would flash orange.
In addition to this, I have noticed that when I go into the monitor's OSD settings it would show '1920x1080p @240Hz' in Windows, but when I go into Overwatch it shows '1920x1080 @144Hz' is this a problem, or is this because I have G-Sync on but the game doesn't always run @240fps?
Any help would be appreciated.
Edit: I have resolved the issue in Overwatch, for some reason the game reset the resolution to 1920x1080 (*144Hz) guess I need to set that file to read-only.
Using G-Sync will lower your fps by about 10fps maybe 15fps at maximum.  Since there is discrepancy I would just not use g-sync if your monitor has option to turn it off.  The reason G-Sync can be good for you is when your framerate drops below 240fps ,,,,,,, like to 150fps or even 100fps.  If you have consistent locked fps then no reason for G-Sync as it will do nothing.  If I were you I would just turn on Vsync and call it a day and turn off G-Sync if the monitor has that option.
Asus Sabertooth x79 / 4930k @ 4500 @ 1.408v / Gigabyte WF 2080 RTX / Corsair VG 64GB @ 1866 & AX1600i & H115i Pro @ 2x Noctua NF-A14 / Carbide 330r Blackout
Scarlett 2i2 Audio Interface / KRK Rokits 10" / Sennheiser HD 650 / Logitech G Pro Wireless Mouse & G915 Linear & G935 & C920 / SL 88 Grand / Cakewalk / NF-A14 Int P12 Ex
AOC 40" 4k Curved / LG 55" OLED C9 120hz / LaCie Porsche Design 2TB & 500GB / Samsung 950 Pro 500GB / 850 Pro 500GB / Crucial m4 500GB / Asus M.2 Card
Thanks for giving me some info about gsync, but unfortunately you have completely missed the point of my post. I was not asking about gsync, I was asking whether there was a reason for my monitor to sometimes flicker to a black screen until I change the input in the OSD.
Well desktop settings and gaming settings are two different things.  Can I ask what OS your using, as this is a common problem with Winblows 10 after the 1809 update.
