Hey guys, hoping someone can help shed light on this. My PC seems to take a long time to post and I’m not sure if it’s normal in this case or not! Once it hits the post screen (after ~23s) it boots just fine and runs like a dream. It’s a fairly new build and I’ve never had a machine take so long to come to life. It’s not a major issue, just wondering if that’s normal for this kind of system or if there’s anything I could do to speed things up a bit.
(I hit Record and Power on at the same time in the video)
Any input most appreciated.
Spec -
Mobo: x299 Msi Raider
CPU: i7 7820x (Noctua NH-D15 Cooler)
RAM: 32Gb Corsair vengeance ddr4
Boot drive: SATA Kingston SSD 240Gb
Media cache drive: SATA Kingston SSD 120Gb
Data Drive: SATA Barracuda 7200rpm 2Tb
Intel Optane: m.2 32Gb
Gpu: Zotac GTX1070 Amp
Case: Corsair Carbide 600q
OS: Windows 10 Pro (1809)
https://linustechtips.com/topic/1023287-slow-post-on-x299/
seems to be just how X299 is, seems to take a long time to initialize the NVME or something, if you enable fastboot in the BIOS you could get it to go a little faster
Builds:
https://linustechtips.com/topic/1023287-slow-post-on-x299/#findComment-12209455
OK, good to know it’s not a problem somewhere. Thanks!
https://linustechtips.com/topic/1023287-slow-post-on-x299/#findComment-12209818
