Ok i need a good ATX motherboard that can overclock a 3770k paired with an h100i. Nothing too expensive. Budget is $150.
Take the board with the most power phases between Asus, Gigabyte, MSI at the price range. Asrock would be the cheapest, but the power phases on the other boards are better. Price varies, and there are open box/sales etc. If you buy open box at a store, check the socket for bent pins and make sure it has an IO shield. You can find some pretty darn good deals on open box z77 boards sometimes.
On z87 powerphases mean jack. On z77 they meant something. Asrock is fine on z87 for this reason.
Same thing applies to AMD chips. Take the most powerphases between Asus/Gigabyte though, because they make the better AMD boards. Why is Haswell different? On die VRM. Z97 will prob go back to the normal "premium motherboard for premium overclock".
CPU:24/7-4770k @ 4.5ghz/4.0 cache @ 1.22V override, 1.776 VCCIN. MB: Z87-G41 PC Mate. Cooling: Hyper 212 evo push/pull. Ram: Gskill Ares 1600 CL9 @ 2133 1.56v 10-12-10-31-T1 150 TRFC. Case: HAF 912 stock fans (no LED crap). HD: Seagate Barracuda 1 TB. Display: Dell S2340M IPS. GPU: Sapphire Tri-x R9 290. PSU:CX600M OS: Win 7 64 bit/Mac OS X Mavericks, dual boot Hackintosh.
https://linustechtips.com/topic/102287-need-a-motherboard/#findComment-1368090
Z77X-UD3H
https://linustechtips.com/topic/102287-need-a-motherboard/#findComment-1368128
Sabertooth is one of the best! Also looks the best!
Hope I could help!
Specs: CPU: AMD FX-8320 @4.0ghz GPU: ASUS DCUII GTX 770 PSU: EVGA Supernova 750g CASE: Fractal Define R4 RAM: 8 Gigabytes ADATA 1333 Mhz MOBO: GIGABYTE GA-990FXA-UD3
https://linustechtips.com/topic/102287-need-a-motherboard/#findComment-1368130
UD3H, Extreme 4, G45. Not sure about the prices but they are good mobos.
CPU: Intel i7 8700K | CPU Cooler: be quiet! Dark Rock Pro 3 | RAM: Kingston HyperX 2x8GB | Motherboard: Asus ROG Z370-E | GPU: MSI GTX 970 | HDD: Seagate Barracuda 1TB & 2TB | SSD: Samsung 840 EVO 250GB & 970 EVO M.2 500GB | Case: Phanteks Enthoo Evolv X | PSU: Silverstone Platinum Strider 1100W | Monitor: AOC i2367Fh | Headphones: ATH-M40X | Mic: Antlion ModMic 4 | Keyboard: Corsair K70 RGB w/ MX Browns | Mouse: Logitech G502 HERO
Make sure you quote or mention the person you're replying to in your comment. Also remember to follow your thread when creating it to get a notification every time someone replies.
Be nice and have fun. Cheers!
https://linustechtips.com/topic/102287-need-a-motherboard/#findComment-1368159
comparing amount of phases on a motherboard or any device is not a fair comparison.
each manufacturer uses a different rated FET and could mean buying more and getting
less. someone using a 8+2 vs 10+2, the rating of the FET at 8 times 30AMP vs 10 times
20AMP. very misleading and very true.
and i believe on the Z87 platform, they moved the power regulator to the IC in the CPU,
but the power phases are still mounted to the motherboard. so power phases on the Z87
is as important, just that the control has been moved to the CPU and not on the mobo.
https://linustechtips.com/topic/102287-need-a-motherboard/#findComment-1369929
Look, unless you're going for world record overclocks, you're not going to get any gain from better power delivery at all, especially not for an LGA1155 processor, maybe with LGA2011, but LGA1155 not so.
I've tested a 3570K I've had on a high end motherboard and a lower end board as well as on both P67 and Z77 and I couldn't get a higher overclock on any of them.
Yes, get a better board for better features. Yes, get a better board for better expansion. Yes, get a better board for better looks. However, don't think that you're going to get any extra performance out of it, all Z77 boards will perform essentially the same.
My Personal Rig - AMD 3970X | ASUS sTRX4-Pro | RTX 2080 Super | 64GB Corsair Vengeance Pro RGB DDR4 | CoolerMaster H500P Mesh
My Wife's Rig - AMD 3900X | MSI B450I Gaming | 5500 XT 4GB | 32GB Corsair Vengeance LPX DDR4-3200 | Silverstone SG13 White
https://linustechtips.com/topic/102287-need-a-motherboard/#findComment-1370304
MSi Mpower.
At that budget, overclock performance matters less than board lifetime under overclock. So you want VRM components that aren't bottom of the barrel but you also need the board to not have a wafer thin PCB.
At the very minimum, AsRock Extreme 4.
In case the moderators do not ban me as requested, this is a notice that I have left and am not coming back.
https://linustechtips.com/topic/102287-need-a-motherboard/#findComment-1370955
