I bought a old fanatec speedster pure. It had the old 9 pin connector so i bought a usb adapter as well. When i connect it to the computer windows recognizes it as twin usb joystick. When i try to use it the wheel dosent do anything and i cant seem to find any drivers for it either. Does anyone know what i could do about this? Thanks
https://linustechtips.com/topic/1022775-ps2-controller-for-pc/
Are you trying to use it with PCSX2? If so doesn't the plugin have something where you can specify that It's a wheel rather than a controller
CPU: Intel Core i7-4790K | GPU: GTX 1080Ti | Case: Corsair 750D Airflow | Motherboard: ASUS Maximus Formula VI | RAM: 16GB Vengeance Pro | PSU: Corsair AX860
SSD/HDD(s): SAMSUNG 850 EVO 120GB, SAMSUNG PM830 256GB, SEAGATE 6TB | Optical Drive: Sony Optiarc AD-5280S CB-PLUS
https://linustechtips.com/topic/1022775-ps2-controller-for-pc/#findComment-12204703
Remember the PC only sees the usb adapter, not each controller as independent devices. If the wheel doesn't show up my two first thoughts are either it is not working /broken or the usb adapter isn't compatible with it
HEDT: i9 10980XE @ 4.9 gHz, 64GB @ 3600mHz CL14 G.Skill Trident-Z DDR4, 2x Nvidia Titan RTX NVLink SLI, Corsair AX1600i, Samsung 960 Pro 2TB OS/apps, Samsung 850 EVO 4TB media, LG 38GL950G-B monitor, Drop CTRL keyboard, Decus Respec mouse
Laptop: Razer Blade Pro 2019 9750H model, 32GB @ 3200mHz CL18 G.Skill Ripjaws DDR4, 2x Samsung 960 Pro 1TB RAID0, repasted with Thermal Grizzly Kryonaut
Gaming Rig: i9 9900ks @ 5.2ghz, 32GB @ 4000mHz CL17 G.Skill Trident-Z DDR4, EVGA RTX 2080 Ti Kingpin, Corsair HX1200, Samsung 970 EVO Plus 2TB, Asus PG348Q monitor, Corsair K70 LUX RGB keyboard, Corsair Ironclaw mouse
HTPC: i7 7700 (delidded + LM), 16GB @ 2666mHz CL15 Corsair Vengeance LPX DDR4, MSI Geforce GTX 1070 Gaming X, Corsair SFX 600, Samsung 850 Pro 512gb, Samsung Q55R TV, Filco Majestouch Convertible 2 TKL keyboard, Logitech G403 wireless mouse
https://linustechtips.com/topic/1022775-ps2-controller-for-pc/#findComment-12206553
