Is there a linus video on how to replace the power supply in the computer? i have found some videos from other users on youtube but none really seem up to date? theyre all using stock walmart looking computers..
i found a video linus made with the graphics card replacement i am watching now but not a power supply replacement.. only the moduler information video
 in case this is needed
CORSAIR VS Series, VS650, 650 Watt, 80+ White Certified, Non-Modular Power Supply
and this is the graphic card ill be installing after i add the new card
ASUS GeForce GTX 1060 6GB Dual-Fan OC Edition VR Ready Dual HDMI DP 1.4 Gaming Graphics Card (DUAL-GTX1060-O6G)
https://linustechtips.com/topic/1021606-new-power-supply/
Any "How to build a PC" video should walk you through the basics of power supply installation.
Here's a video from Bitwit queued up to power supply installation process.
https://linustechtips.com/topic/1021606-new-power-supply/#findComment-12193723
thank you! i am watching the video! its very helpful because he talks about the other USB ports power button wires etc!
no other videos i found has this thanks alot
https://linustechtips.com/topic/1021606-new-power-supply/#findComment-12193738
Don't get a VS650. You DO NOT need 650W, a good 400W is EASILY enough.
Get something like a Corsair CX450 (Check your GPU only needs 1 PCIe connector if you get that), Corsair CX450M, BeQuiet PurePower 10 or 11 400W (including CM variants) instead.
https://linustechtips.com/topic/1021606-new-power-supply/#findComment-12194299
i already bought it and i figured it would be good since im going to be replaceing my motherboard and getting a new cpu etc plus i have 7 fans in my case and the person who created it put abunch of LED strips etc according to the tech videos its not going to harm anything having a better watt power supply as per what linus has said
https://linustechtips.com/topic/1021606-new-power-supply/#findComment-12197751
It is going to be detrimental, in the sense that you're getting a significantly worse PSU, and getting no benefit at all.
Please don't write super long sentences.
https://linustechtips.com/topic/1021606-new-power-supply/#findComment-12197974
why respond if youre going to be a dick?
linus said it isnt going to hurt anything.. youre telling me hes wrong?
https://linustechtips.com/topic/1021606-new-power-supply/#findComment-12197981
Yes. When it comes to PSUs, everyone at LMG so absolutely clueless. I'd rather take advice from my cat than from anyone at LMG.
https://linustechtips.com/topic/1021606-new-power-supply/#findComment-12197989
then ill issue a refund and stick with my 450 power supply i got until i upgrade my hardware ... this just means i can install my graphics card when i get home today.. awesome
https://linustechtips.com/topic/1021606-new-power-supply/#findComment-12197991
Which model 450W do you have? Depending on what model it is, you may be better off with the Corsair VS...
https://linustechtips.com/topic/1021606-new-power-supply/#findComment-12198009
the guy who built it put in logisys 400 or 450.. when i googled the gtx 1060 it shows it requires a 400 watt.. on asus website for the graphics card it says 500 so thats why i went 650 cause i was gonna change out the motherboard and cpu etc but not right now
https://linustechtips.com/topic/1021606-new-power-supply/#findComment-12198016
What guys advised you above is that you don't need a 650 mediocre psu like vs but you need a 400-450 quality psu for your system. That Logisys is probably a bad unit from what i am googling, so between these two keep the VS.
https://linustechtips.com/topic/1021606-new-power-supply/#findComment-12198128
the vs is medicore? its $60 and has tons of great reviews? idk..
https://linustechtips.com/topic/1021606-new-power-supply/#findComment-12198144
9 minutes ago, Evilwendie413 said:
then whats a good 500-550 psu on amazon ? i dont like to order off of any other sites besides newegg
on newegg the vs is under one of the best selling power supplies page? idk
at corsairs level I would say at least the cx(m). outside of it I refer you to the psu tier list down my signature. tier c+
https://linustechtips.com/topic/1021606-new-power-supply/#findComment-12198207
Please don't go for Corsair VS series select CX series or up.VS series r not for gaming,I got random shutdown while gaming on VS550 and now its dead.It will work fine for 2 months that's it.Its not for heavy use like gaming.
I too bought it seeing reviews and ratings.?‍♂️
My Rig
HP Omen 16 | 13th Gen Intel(R) Core(TM) i7-13700HX | 16 GB DDR5 RAM | NVIDIA Geforce RTX 4060 8 GB | 512GB PCIe Gen4 NVMe TLC M.2 SSD |
16.1-inch (40.9 cm) 1920 x 1080 165Hz | RGB Backlit Keyboard |
https://linustechtips.com/topic/1021606-new-power-supply/#findComment-12198279
A 1060 is a 120W card and what the manufacturers is recommending is a wattage of the PSU for your whole system for a normal gaming PC, not just for the card. And they even add some extra W for to be on the safe side so not some crazy person tries to sue them.
I have a Watt-meter and I run a dual Xeon E5-2670-setup with 112 GB of DDR3 RAM, a 1060 and Vega 56 doing computations right now both on CPU and the 1060 and I am pulling about 500W from the wall with the monitor included. And those two CPU:s is good for 115W each under full load... Now i'm not loading all cores to 100% so say the draw about 90-100W each right now and the 1060 is drawing 95W fully loaded with this particular workload.
https://linustechtips.com/topic/1021606-new-power-supply/#findComment-12198359
i went on that list and theres hardly any 500 or 550's on the c tier and the ones that are on there is around $70 to $140 besides the rosewill..
thats a pretty decent one then? id prefer the power supply be under $70 .. more likely $60- would be awesome and none mod cause i have no idea what id be doing
i found this https://www.newegg.com/Rosewill-Power-Supplies/BrandSubCat/ID-2177-58
https://linustechtips.com/topic/1021606-new-power-supply/#findComment-12201561
rosewill has some decent psus. but you should look around much lower wattagewise, i personally run a 1070 ti with a 8600k on this one, and it's 40 bucks after rebate
https://m.newegg.com/products/N82E16817139147
https://linustechtips.com/topic/1021606-new-power-supply/#findComment-12201574
https://www.newegg.com/Product/Product.aspx?Item=N82E16817553039&Description=gx-f&cm_re=gx-f-_-17-553-039-_-Product
Ex-EX build: Liquidfy C+... R.I.P.
Ex-build:
Meshify C – sold
Ryzen 5 1600x @4.0 GHz/1.4V – sold
Gigabyte X370 Aorus Gaming K7 – sold
Corsair Vengeance LPX 2x8 GB @3200 Mhz – sold
Alpenfoehn Brocken 3 Black Edition – it's somewhere
Sapphire Vega 56 Pulse – ded
Intel SSD 660p 1TB – sold
be Quiet! Straight Power 11 750w – sold
https://linustechtips.com/topic/1021606-new-power-supply/#findComment-12201619
thanks
3 hours ago, Quadriplegic said:
thanks
gonna look into these 2 and figure out which one i want
https://linustechtips.com/topic/1021606-new-power-supply/#findComment-12201978
