Fan control
Solved by WoodenMarker,
7 minutes ago, Mike87 said:I have set up the fan control settings in the Bios, those are fine. If I use splitters, will I be able to control the RPM or only the %? What will I see if I have 2 fans connected to one control header? The RPM of only one of the fans or will I see nothing?
Sorry its in german. those are 3 of the 5 fans. the rest are also 120mm with 1200 RPM.
This was answered in your previous thread.
If you're using 4pin pwm fans, split them off of the cpu_fan 1 / 2 headers. If 3pin fans, split them off of the sys_fan1 header.
