Hello,
May I have your advice?
I am currently planning my first PC build. I will use it for light to medium gaming in 1080p, probably 1440p down the line. I hope to be able to use it for as long as possible (min. 5 years) without upgrading major parts. The system should be as quiet as it can possibly be and I am quite keen on aesthetics. It is to note that I will probably add the GPU down the line and need to use something like a cheap GT710 with the AMD CPUs.
My budget is 1200€ and the location is Germany.
These are the configurations:
SFF build (between 1000€ and 1200€, depending on configuration)
CPU: - Intel Core i5 9400 or
     - Intel Core i7 8700 or
     - AMD Ryzen 5 2600 or
     - AMD Ryzen 7 2700
CPU cooler: Noctua NH-L12
Mainboard: - Asus ROG Strix B360-I
           - Asus ROG Strix B450-I
Memory: - Corsair Vengeance LPX 1x8 GB 2666mHz (for Intel)
                        - Corsair Vengeance LPX 1x8 GB 3000mHz (for AMD)
both doubled later
GPU: - Nvidia GTX 1060 6GB FE
     - Nvidia RTX 2060 6GB FE
Storage: Samsung 970 Evo 500GB
Powersupply: Corsair SF450 80PLUS Gold
Case: Louqe Ghost S1
mini/midi tower build (between 900€ and 1200€, depending on configuration)
     - AMD Ryzen 7 2700 or
     - AMD Ryzen 7 2700X
CPU cooler: - Be quiet! Dark Base 4
            - NZXT Kraken M22
           - Asus ROG Strix Z360-G
Memory: - Corsair Vengeance RGB Pro 2x8 GB 2666mHz (for Intel)
        - Corsair Vengeance RGB Pro 2x8 GB 3200mHz (for AMD)
Powersupply: Corsair RM550X 80PLUS Gold
Case: - NZXT H200i
      - Phanteks Enthoo Evolv
The Louqe Ghost is a beautiful case, but do I need to be aware of any issues with such small cases? Which CPU/GPU is the best for my needs? And is there anything else I forgot about?
Thank you again!
https://linustechtips.com/topic/1021038-first-pc-build/
3 minutes ago, hohoho said:
The Corsair 570x is quite a lot too big for my opinion and why would I need a z-series intel motherboard if the CPUs are locked?
Also, Corsair unfortunately does not sell the RGB in single sticks, which is pretty annoying.
All true....
choosing the right things is something for your own i cant really help with that
https://linustechtips.com/topic/1021038-first-pc-build/#findComment-12188416
Lets just say that your ambitions do not meet reality.
If you plan on gaming at 1440p in the future, you need GTX1080 or higher if you need future proof for a few years. GTX1060 is getting outclassed by today's standards.
As for the CPU, don't get i5. Game are using more and more cores, so i5s slowly but surely getting performance hit in modern games. So either get 8700k or 9900k, or go with Ryzen.  Might want to wait for Ryzen 3000 reviews.
If you want silent build, don't pick FE cards, they're fairly loud.
Main system: Ryzen 7 7800X3D / Asus TUF Gaming B650-Plus / G.Skill Trident Z5 NEO 32GB 6000Mhz / Zotac RTX 5090 SOLID OC/ x2 WD_BLACK NS770 2TBs/ Corsair HX1000i/ NZXT H5 Flow
https://linustechtips.com/topic/1021038-first-pc-build/#findComment-12188423
By the time games have a noticable performance increase from 8 cores over 6 cores, the 9700k/9900k's IPC will have made themselves irrelevant anyway.
https://linustechtips.com/topic/1021038-first-pc-build/#findComment-12188465
16 hours ago, hohoho said:
Hello,
Thank you again!
Nice post, you've clearly done a fair bit of research.
With the parts you have decided on, I would build a system similar to this: https://de.pcpartpicker.com/list/JDrKQZ.
The 1060 is just acting as a placeholder for a 2060.
"Make sense? Oh, what fun is there in making sense?"
-Discord
https://linustechtips.com/topic/1021038-first-pc-build/#findComment-12188638
Why nvme?
https://linustechtips.com/topic/1021038-first-pc-build/#findComment-12188662
51 minutes ago, xKyric said:
It's what @hohoho listed on the original post, so I'm assuming it's important to him/her.
44 minutes ago, ears_ears said:
@hohoho for what you're doing NVMe is useless, go with regular sata ssd
I will get this from a friend who does not need it anymore. Normally I would go with a regular SATA, but under the circumstance
https://linustechtips.com/topic/1021038-first-pc-build/#findComment-12190653
Thank you.
The MSI - GeForce GTX 1060 6GB ARMOR OC costs the same as a 1070/2060, so I will probably not go with it.
https://linustechtips.com/topic/1021038-first-pc-build/#findComment-12190661
1 hour ago, hohoho said:
Thank you.
The 1060 is only on the list because the 2060 isn't released yet, it's just acting as a placeholder.
You should definitely get a 2060/1070.
-Discord
https://linustechtips.com/topic/1021038-first-pc-build/#findComment-12191688
