Is this solution possible?
By
TheHighSenpai
in Networking
in Networking
Solved by ololax,
Yes that is possible, would personally look into having "DMZ" for the second router, and make sure not to use same subnet (192.168.1.x for main router, and then 192.168.2.x for vpn router) to try and avoid problems there.
You dont want to be able to talk between the vpn routers network and the other one? printers or such?
thedood2k ·
Posted in Power Supplies2 -
DARTHDIVIDER0213 ·
Posted in Troubleshooting8 -
1
Xx-albinos-xX ·
Posted in Troubleshooting10 -
2
_Darasuum_ ·
Posted in Power Supplies6 -
1
play_circle_filled
Latest From Linus Tech Tips:
play_circle_filled
Latest From ShortCircuit:
