Can't decide?? HP Omen vs HP Pavillion vs Dell Inspiron
renderTimingPixel.pngHello everyone,
Currently in the midst of buying a new gaming laptop but on a budget. Narrowed it down to 2 gaming laptops.
  1. HP Pavilion 15-cx0036TX - GTX1050Ti 4GB, i7-8750H, 16GB RAM, 128GB M.2 SSD + 1TB HDD, 15.6'' 1080p FHD. @$1790.00
  2. HP Omen 15-CE040TX - GTX1050 2GB, i7-7700HQ, 16GB RAM, 256GB M.2 SSD + 1TB HDD, 15.6'' 1080p IPS FHD. @$1750.00
Will mainly use this laptop for playing Dota 2 (don't need maxed out settings but preferably mid-high settings) and everyday use. Any helpful advice or recommendations would be useful! Thank you.
https://linustechtips.com/topic/1020809-help-with-deciding/
Neither are the best options
Where are you from? Budget? Any preference on weight and battery life?
Desktop specs:
AMD Ryzen 5 5600 Thermalright Peerless Assassin 120 SE ARGB Gigabyte B550M DS3H mATX
Asrock Challenger Pro OC Radeon RX 6700 XT Corsair Vengeance LPX 16GB (8Gx2) 3600MHz CL18 Kingston NV2 1TB PCIe 4.0 NVMe SSD
Montech Century 850W Gold Tecware Nexus Air (Black) ATX Mid Tower
Laptop: Lenovo Ideapad 5 Pro 16ACH6
Phone: Xiaomi Redmi Note 10 Pro 8+128
https://linustechtips.com/topic/1020809-help-with-deciding/#findComment-12186800
New Zealand. My budget is currently $1,500-$2,000 NZD. No preference on weight (not over 5kg) or battery life as it will be put on a desk and played while plugged in. Only preference would be it has to play dota 2 at above 60fps and be stable and decent monitor. Can also buy online and ship here and am open to recommendations but would prefer something locally.
Sites in NZ:
https://www.pbtech.co.nz/category/computers/laptops
https://www.mightyape.co.nz/computers/laptops-and-tablets
https://www.justlaptops.co.nz/
https://linustechtips.com/topic/1020809-help-with-deciding/#findComment-12187857
Options are limited it seems
Aspire 7 would be the best choice, spec wise and display quality. However it has poor cooling which requires undervolt+repaste
Desktop specs:
https://linustechtips.com/topic/1020809-help-with-deciding/#findComment-12189200
