Personally I'm a fan of the carbide series, and the air 240 has a unique look to it so I'd prefer that one.
Primary PC:
PSU tier list
How many watts do I need?
https://linustechtips.com/topic/1020538-high-air-flow-case/#findComment-12184152
The your gear can fit in the 240, get it. I prefer the 540 as I always get atx boards.
Im sure you could fit the pro, quite a bit of room in the case given it’s size.
https://linustechtips.com/topic/1020538-high-air-flow-case/#findComment-12187937
