I just upgraded my PC, and now when I plug in a PS4 Controller, There is a major input lag. When I connect my controller through Bluetooth, basically unnoticeable. Any Ideas?!?!
PC Set up
CPU: I9-9900k
Mobo: Gigabyte Z390 Aorus Pro-Wifi
GPU: MSI RTX 2070 Gamin Z
Cooling: Cooler Master ML360R AIO
RAM: Corsair Vengeance Pro RGB 16 GB 3000MHZ (8GB X 2)
RAM: Corsair Vengence Pro Lighting Enhancement Kit (0GB X 2)
Storage: Samsung 860 EVO 1TB
PSU: EVGA SuperNova G2 750 W 80+ Gold Fully Modular
Case: CoolerMaster MB511 RGB
Build Log found here:
https://linustechtips.com/topic/1020078-ps4-controller-on-pc-input-lag/
well then just use bluetooth or use key board and mouse like everyone else
King of pointless comments? I play castle crashers with a Controller. Literally preferred by everyone to use a controller on this game. Get off this forum if you don't add anything good?
PC Set up
CPU: I9-9900k
3 hours ago, Earnist_ said:
use bluetooth then
"use Bluetooth then" isn't troubleshooting.
PC Set up
CPU: I9-9900k
if there is Input lag when using a wire, but none when Bluetooth, then obviously use Bluetooth, it is an easy fix.
But make sure the USB cord you are using is actually a high quality one, and not an overly extensive length either
also make sure you are plugging it into a USB 3.0 port, as I believe it is faster
✧・゚: *✧・゚:*  Quote for a reply  *:・゚✧*:・゚✧
✧・゚: *✧・゚:*   Ask for discord   *:・゚✧*:・゚✧
yep thats one of the answers i gave him was just use bluetooth then
3.0 is faster but voltage is different i noticed it was less responsive in a 3.0 port. It's not a fix to use Bluetooth, it's a different option. You cant charge over Bluetooth though. Ill try a different cable thanks!
PC Set up
CPU: I9-9900k
10 minutes ago, Earnist_ said:
its windows use an xbox controller then and see if your issue persists
aye! actual advise :) thanks ill try that!
PC Set up
CPU: I9-9900k
A different option that works is still a fix though.... and you could plug in a wall usb hub and plug it into the wall, or connect it with Bluetooth and set it to charge only on your computer
That will probably work best, since it’s a controller for the same company’s things
and plus, the trigger stops on an xbox controller are much more responsive, so there’s a plus
I literally didn't think about just plugging it into the wall... ? That's a fix to the issue.
PC Set up
CPU: I9-9900k
-Thread cleaned-
Please keep comments respectful, on topic, and contributing.
Remember the Community Standards.
Quote
  • Ensure a friendly atmosphere to our visitors and forum members.
  • Encourage the freedom of expression and exchange of information in a mature and responsible manner.
  • "Don't be a dick" - Wil Wheaton.
  • "Be excellent to each other" - Bill and Ted.
  • Remember your audience; both present and future.
