Hardware order
Go to solution Solved by Fivenines,
Alright, thank you for the replies.
However you want. I just put what I thought made sense and what was important to least important.
Ryzen 3800X + MEG ACE w/ Radeon VII + 3733 c14 Trident Z RGB in a Custom Loop powered by Seasonic Prime Ultra Titanium
PSU Tier List | Motherboard Tier List | My Build
https://linustechtips.com/topic/1019990-hardware-order/#findComment-12179255
11 minutes ago, Fivenines said:
Your signature is short and slick, I like it. But should the signature be more user friendly? I guess everyone knows a little about tech here so no need to specify what Ryzen 1800x means.
you don't have to... i just did it this way
https://linustechtips.com/topic/1019990-hardware-order/#findComment-12179292
