HELP! I need somebody
Go to solution Solved by Flyguygamer,
no quality loss.
Yes that was a Beatles reference. Anyways i should say that i am not an audiophile by any means. But i wanted to ask whether  i would lose quality if i just got a m/f 3.5 extension cable to go to the back of the computer to directly plug it in. Or should i get like a different connector of some sort to have a better sound. Btw i need extra length cable for my earbuds either way. Last but not least i have a pair of Klipsch S4 not the S4 II.
Thanx in advance
AMD FX 8350 | 2X XFX RADEON HD7850 | ASUS SABERTOOTH R2.0 | NZXT GUARDIAN 921RB | KINGSTON HYPER-X 2X8GB
https://linustechtips.com/topic/101961-help-i-need-somebody/
HELP! Not just anybody
It's a cable.  As long as the connections are good, it will have no effect until it becomes VERY long.
"Pardon my French but this is just about the most ignorant blanket statement I've ever read. And though this is the internet, I'm not even exaggerating."
https://linustechtips.com/topic/101961-help-i-need-somebody/#findComment-1363788
The band begins at ten to six
When Mr. Kite performs his tricks without a sound
And Mr. H will demonstrate
Ten summersets he'll undertake on solid ground.
Even the Beatles agree, you need a solid ground to make your sound work properly.
Grammar and spelling is not indicative of intelligence/knowledge.  Not having the same opinion does not always mean lack of understanding.
https://linustechtips.com/topic/101961-help-i-need-somebody/#findComment-1364842
