My story so far: PC bluescreened on boot (irql_not_less_or_equal) with artifacts on screen. Repeated booting yielded no result: BSOD when it got to windows login (irql_not_less_or_equal; memory_management; kernel_security_check_failure). After next few attempts, the PC would freeze whenever windows logo appeared when it tried to boot up. BIOS POST was fine. Launching in safe mode didn't help.
I though it was the last of my GPU, since it was old (~8 years), and got a new one (Asus 750ti 2gb). However, after installing the new GPU, there was still no video output.
At this point I have no clue what to do next.
Specs:
Q9500 @ stock
4gb ddr3
ASUS p5g41t mlx
GPU old: Inno 3d NVIDIA GT 440 1 GB
GPU new: ASUS NVIDIA GTX 750 ti 2 GB
https://linustechtips.com/topic/1019371-need-help-no-video-output/
Does iGPU work? (You might need to run DDU and clear the drivers)
--- Purple Prime ---
i7 8700k + Hyper 212 Evo | MSI Z370 Gaming Pro CarbonG-Skill Trident Z 3000Mhz RGB 16GB | Gigabyte Aorus GTX 1080ti
Crucial MX500 500GB | WD Black 2TB | Corsair RM850i | Fractal Design Define R4LG 27UD68-P | Logitech G502 + G910 | Windows 10 Pro
--- Proteus Server ---
AyyMD Ryzen 5 3600 | Asrock B450m Pro-4 | Crucial Ballistix Sport LT 32 GB (2 x 16 GB) | Sapphire RX570 NITRO+ 8GB
Crucial MX500 1TB + Samsung Spinpoint F4 2TB + Seagate 1TB 2.5" + 5TB iDrive  | Windows 10 Pro (Temporary)
--- Camera Stuff ---
Canon EOS 77D | Canon EF-S 18-55 f/4-5.6 IS STM | Canon EF-S 55-250 f/4-5.6 IS STM | Canon EF 50mm f/1.8 STM
Zoom H5 + XY-5
Phone - Oneplus 6T
Just now, InHoomanWasTaken said:
No iGpu
Have you tried windows recovery? As in the USB stick/CD method.
It sounds like general windows drivers are missing.
Maybe a windows reinstall if possible?
Zoom H5 + XY-5
Phone - Oneplus 6T
Well...
For starters, i can't even get into BIOS right now. I have a windows recovery USB, and if that's not detected i have an ISO image burned onto a DVD
Well...
Try minimal booting, Only CPU, One stick of ram and GPU.
Reseat GPU and ram also.
Zoom H5 + XY-5
Phone - Oneplus 6T
Done that, no change.
While doing that, however, i noticed that one of the capacitors on the mobo is blown.
So that might be the issue all along
(pic related, blown capacitor is in the middle of the photo)
That does sound like an issue, Maybe time for an upgrade?
Or of course you could try to repair it.
It could also be a power supply issue?
Zoom H5 + XY-5
Phone - Oneplus 6T
PSU is fine (i hope). Will carry the whole system tomorrow to a guy that specializes in electronics repair, maybe he can solve the issue
Yes, it would be a great time for an upgrade. However, that's not my system.
Anyway, thanks for advice. Will update on the situation
