So i recently just put in a custom loop. I was wondering if a higher pump speed is better for thermals? Because a faster pump means more water running over hot components, on the other hand it also means the water spends less time in the radiator being cooled. Does anyone have a definitive answer on which option would help temps more.
https://linustechtips.com/topic/1018213-custom-loop-pump-speed/
Having the fluid circulate faster can help to a certain degree as it will keep the whole loop at a more equal equilibrium, but your results will usually only yield a degree or two. In most situations it's recommended to turn down the pump to a comfortable level and leave it there. I personally idle pump even under full load for reducing noise levels.
-Moved to Liquid and Exotic Cooling-
Edited by W-L
https://linustechtips.com/topic/1018213-custom-loop-pump-speed/#findComment-12162754
As far as I know the minimum acceptable flow rate is around 0.5 GPM and anything above 1 GPM won't do much to your temps.
CPU: i7-12700KF Grill Plate Edition // MOBO: Asus Z690-PLUS WIFI D4 // RAM: 16GB G.Skill Trident Z 3200MHz CL14
GPU: MSI GTX 1080 FE // PSU: Corsair RM750i // CASE: Thermaltake Core X71 // BOOT: Samsung Evo 960 500GB
STORAGE: WD PC SN530 512GB + Samsung Evo 860 500GB // COOLING: Full custom loop // DISPLAY: LG 34UC89G-B
https://linustechtips.com/topic/1018213-custom-loop-pump-speed/#findComment-12163079
Test it and see. Not all loops are the same so neither will the answer.
All of my rigs have different components and a different amount.  Thus my pumps should be running different but I don’t.
https://linustechtips.com/topic/1018213-custom-loop-pump-speed/#findComment-12163837
