Newly built computer does not POST
Go to solution Solved by tjknejrnbtkjw4bk5jbwkejb,
It seems to have been just my stupidity. The RAM wasn't well seated. If you have this problem, make sure the RAM clicks in, and see on the side of the RAM while seated if you can see the golden pins. If you can, try to apply more pressure on the side you can see the golden pins.
This does not apply to any particular motherboard anymore, after solution was posted.
I just built my first desktop. It doesn't POST though. When I press the power button, the power light comes on and the fans start spinning. They are on for 10-20 seconds, until they turn off and back on (reboot?). This repeats, until I turn the computer off. I hear no beeps at any time and I have let it reboot(?) around 10 times with no success. I've tried clearing CMOS and trying each RAM slot with a single stick. Here are the computer's specs:
Processor / APU: Ryzen 5 2400G
Mobo: ASRock B450M Pro4
RAM: Kingston HyperX Predator 2 × 4 Gb DDR4 3000 MHz
HDD: WD Blue WD10EZEX 1 TB 7200 RPM
SSD: Kingston A400 120 Gb
Case: Fractal Design Core 1100
PSU: Corsair CX450M
Wi-Fi card: TP-link TL-WN881ND
EDIT #1: I'm not 100% sure, but it seems that the computer accesses the HDD (empty) for a few seconds
https://linustechtips.com/topic/1017952-newly-built-computer-does-not-post/
