Not possible. Your average UPS that can hold up a 500 watt PSU for a few minutes is going to weigh anywhere from 30 to 50lbs most likely. Basically take your average PSU and multiple it's size by 4x or 5x to fit the batteries inside.
Edit:
When I say "not possible" I do mean in normal size computer power supplies
Current Network Layout:
Current Build Log/PC:
Storage Server Setup:
Prior Build Log/PC:
https://linustechtips.com/topic/1017524-psu-with-ups/#findComment-12156619
14 hours ago, Billy Pilgrim said:
Just wondering, are there any PSUs with built in UPSs?
Like Jon mentioned, there are. but they are rare and expensive.
The Problem is the batterys. And those are the biggest part of such things. And they are heavy.
So it doesn't make too much sense to do that for that reason.
"Hell is full of good meanings, but Heaven is full of good works"
https://linustechtips.com/topic/1017524-psu-with-ups/#findComment-12158853
