it's hard to say much when we don't know your priorities and hardware.
Desktop benching:
https://linustechtips.com/topic/1017370-case-help/#findComment-12155286
On 1/5/2019 at 4:56 AM, Josho17 said:
The Corsair Spec and InWin don't have great Airflow. I personally don't like the H500i because it's quite common, but that's because it's a good case. Looks good, good airflow and solid build.
An alternative I might suggest is the Lian Li Lancool One, GN reviewed it well and they know their cases. You can remove the PSU shrouds to improve airflow too. It's pretty cheap for a Lian Li case at $90 considering their build quality. It doesn't come with too many fans but that may be a blessing since Lian Li fans use proprietary connectors. Also I like the RGB front thingy.
https://linustechtips.com/topic/1017370-case-help/#findComment-12169418
If budget permits you might consider Phanteks ENTHOO EVOLV X GLASS (Black).
Fractal Design - Meshify C TG is a good choice, but the psu would have to be changed. Perhaps to SeaSonic FOCUS Plus 650 Gold.
https://linustechtips.com/topic/1017370-case-help/#findComment-12169624
