i have a ps4 and i'm planning on upgrading the hdd
does the hitachi 1.5tb laptop drive be supported
any laptop drive or 2.5inch ssd is supported, you just need to format it in the playstation and it will work.
Listen if you care.
https://linustechtips.com/topic/101726-ps4-hard-drive/#findComment-1360158
It has to be 9.5mm thick at most as well
Main rig: i7 3770K @ 4.54, Sapphire R9 290, Sabertooth Z77, 16 GB Mushkin Redline 2133, Lian Li PC-P50R, Seasonic 860xp Platinum, Kingston Hyper X 3K 240GB
freeNAS server: AMD Athlon II 170u 20W, 5 x 3TB WD Red in raid-z1 (12 TB)
media centre: AMD A10-5700, crucial M4 (boot), running XBMC,4 x 3TB WD Red, 3 x 3TB WD green + 2TB green in FlexRAID (17 TB)
https://linustechtips.com/topic/101726-ps4-hard-drive/#findComment-1360195
