Hello,
I bought Trident Z RGB DDR4-3200 and a Asus Rog Strix x399-E Gaming motherboard.
The memory speeds aren't showing (shows only 2133mhz instead of 3200mhz) so I did the memory configurations according to this document.
Although when I restart the PC, the RAM lights won't work, stays on for a few seconds, shuts down by itself for a few seconds more and turns on again.
Resetting the settings makes the PC work again properly.
I did update the BIOS and everything seems connected as properly.
What else should I try?
Thank you.
https://linustechtips.com/topic/1016106-gskill-memory-problem/
