PC Build Help
Go to solution Solved by Optane^,
Building is quite easy. You can follow a guide on youtube.
I've been watching LTT and other build tutorials for 1 year but im not sure if i can build a computer because my parents are not intrested in the subject and tell me that if i can build it then i could buy it but im not sure so can anyone point out some hard to do things in the reply of this post?
By The Way here are the specs
eVGA NVIDIA GeForce GTX 980 Ti
AMD Ryzen 7 2700 Processor
ASUS PRIME B350-PLUS AM4 Motherboard
Corsair 16gb RAM (8x2) DDR4 3000MHz
Corsair ATX Case
CORSAIR CX750 ATX PSU - 750 W
Corsair 120gb M.2 NVME SSD
Samsung 500gb sata SSD
https://linustechtips.com/topic/1016070-pc-build-help/
PC - i7 12700K | EVGA FTW3 3090 | Corsair H150i | ASUS ROG Strix Z690-A | 32GB Corsair Vengance | Lian Li O11 Evo & EVGA 1k PSU
If my post solved your problem/answered your question, please consider marking it as "solved"
https://linustechtips.com/topic/1016070-pc-build-help/#findComment-12143231
Corsair ATX Case
oh boy, that can use some changes... you bought this already or is this a plan?
https://linustechtips.com/topic/1016070-pc-build-help/#findComment-12143252
Use a Pcpartpicker list for the build, you will find it very convenient.
Primary PC:
PSU tier list
How many watts do I need?
https://linustechtips.com/topic/1016070-pc-build-help/#findComment-12143272
1 minute ago, jancc said:
and with that b45 MB you could replace the graphics card with an AMD one(for potential crossfire)
Crossfire isn't necessarily any more practical than SLI.
Primary PC:
PSU tier list
https://linustechtips.com/topic/1016070-pc-build-help/#findComment-12143280
Just now, Windows Server 2008 said:
my budget is £1000 and the 980ti will cost me £260
Seems an alright price for the card, which model is it?
Primary PC:
PSU tier list
https://linustechtips.com/topic/1016070-pc-build-help/#findComment-12143283
https://www.ebay.co.uk/itm/eVGA-NVIDIA-GeForce-GTX-980-Ti-6144-MB-06G-P4-4995-KR-Graphics-Card/113451503493?epid=219530815&hash=item1a6a3c8f85:g:fjIAAOSwwtdcE6-K:rk:9:pf:0&LH_BIN=1
i need the card to be with SLI or crossfire
https://linustechtips.com/topic/1016070-pc-build-help/#findComment-12143289
2 minutes ago, Windows Server 2008 said:
I thought it would be something like a strix, now it seems a bit overpriced. That's like a base model 980 ti
Primary PC:
PSU tier list
https://linustechtips.com/topic/1016070-pc-build-help/#findComment-12143292
