I’m so excited, I finally completed my first build a couple of minutes ago , it took me forever though , can’t wait to finally get into the world of pc gaming .
The build specs are :
Ryzen 5 2600
Asus B450 mobo
GTX 1070 Founders Edition
16gb Trident Z rgb ram
Kingston hyperX 240gb rgb SSD
Powerspec 650W 80+ psu
and for the case a Cooler master master box 5 lite .
let me know if you think it turned out good for a first build !
https://linustechtips.com/topic/1015873-completed-my-first-build/
Pretty awesome first build. Reminds me a bit of mine, I had a haswell i7 I got from a friend, and a 770, but it was when an SSD was pretty expensive and RGB was yet to be user friendly.
Primary PC:
PSU tier list
How many watts do I need?
Thanks man ! All I need to do now is install windows ,update drivers and then I’ll be good to go .
Congratulation for your 1st build! This is a good build..
It's already neat interior, but I would put more effort to the cable management to hide that excessive additional PCIE cable plug above the PSU shroud. Also, Why you took off the 1st expansion slot cover? Or maybe you haven't put it back when you took the pic..
Btw, I've never ever seen an RGB SSD before this.. I completely didn't expect that RGB is featured on storage drives.. SSD with RGB on it is just too much for me..
My system specs:
CPU: Intel Core i7-8700K, 5GHz Delidded LM || CPU Cooler: Noctua NH-C14S w/ NF-A15 & NF-A14 Chromax fans in push-pull cofiguration || Motherboard: MSI Z370i Gaming Pro Carbon AC || RAM: Corsair Vengeance LPX DDR4 2x8Gb 2666 || GPU: EVGA GTX 1060 6Gb FTW2+ DT || Storage: Samsung 860 Evo M.2 SATA SSD 250Gb, 2x 2.5" HDDs 1Tb & 500Gb || ODD: 9mm Slim DVD RW || PSU: Corsair SF600 80+ Platinum || Case: Cougar QBX + 1x Noctua NF-R8 front intake + 2x Noctua NF-F12 iPPC top exhaust + Cougar stock 92mm DC fan rear exhaust || Monitor: ASUS VG248QE || Keyboard: Ducky One 2 Mini Cherry MX Red || Mouse: Logitech G703 || Audio: Corsair HS70 Wireless || Other: XBox One S Controler
My build logs:
