It's the old boot drive from my Aero 15 that I just upgraded to a Toshiba - wanted to clone my files over but I left it in my workbench a little too long and Microsoft applied an update (New build of Windows).
Now, nearly 100% of the time it does not show up in BIOS, Disk Management, or Disk Part. When it is able to boot, it locks up either at the lock screen before I unlock it, or on the desktop, and BSODs to critical_process_died
What should I be doing to try and fix this? Is it hardware or software?
I did try it in a total of three different M.2 slots over 2 PCs and it doesn't show up in any, while a HP EX920 will show up in all three. (I'm guessing it's hardware so should I just RMA it to save some trouble?)
EDIT:
Was able to run an SFC Scan on it through sheer luck and it didn't fix the issue.
Daily Driver: Redmi Book Pro 14 - Core Ultra 7 155H | 32GB/1TB
Primary Desktop: NCase M1 - Ryzen 7 7800X3D/RX 6950XT | 32GB/2TB
Travel PC: Fractal Terra - Ryzen 7 5800X/RTX 3060 Ti | 16GB/1TB
I have too many computers. List here.
https://linustechtips.com/topic/1015384-bad-ssd-need-help/
For any drive problems that I may have, I use AOMEI Partition Assistant.  I would put a link for it but for some reason LTT forums don't handshake very well with that website.  There is a free version of the AOMEI software and that is what I have been using for a long time.
https://linustechtips.com/topic/1015384-bad-ssd-need-help/#findComment-12138286
Yeah, no. If it doesn't show up in Bios, disk management, disk part, and gparted it's not gonna show up in that either :(
https://linustechtips.com/topic/1015384-bad-ssd-need-help/#findComment-12138770
Evidently it must have shown up in the BIOS, otherwise the original poster would not have said this.
https://linustechtips.com/topic/1015384-bad-ssd-need-help/#findComment-12139057
Dat Me.
It only shows up once in a blue moon - corrupted drives do this until they are so corrupted they don't show any more :)
https://linustechtips.com/topic/1015384-bad-ssd-need-help/#findComment-12139744
