Overclocking Help
Go to solution Solved by Brooksie359,
1 hour ago, Big Baller said:
Last question.
Is 8gb or 16gb enough? Just 1080p@60fps gaming on like BF5, Fortnite, Overwatch, Witcher 3, med to high settings.
BF5 wants 16gb. Watch hardwareunboxeds video on how much ram do you really need for gaming.
I am going with a Ryzen 5 2600 and an MSI Armor OC RX 580
I used thebottlenecker.com to see if any bottleneck, and it says GPU bottleneck.
Should I OC just my GPU or should I overclock my CPU as well? Will OC my CPU just waste electricity or will it boost performance?
I plan on a GTX 1080 Ti later on, which thebottlenecker.com recommends.
P.S. Is thebottlenecker.com a good site to use to see bottlenecking or naw?
https://linustechtips.com/topic/1015342-overclocking-help/
2 minutes ago, Big Baller said:
thebottlenecker.com
Bogus website, ignore. Also, don't get armor, it's a crap cooler design.
Primary PC:
PSU tier list
How many watts do I need?
https://linustechtips.com/topic/1015342-overclocking-help/#findComment-12137765
3 minutes ago, Big Baller said:
It there a calculator I can use
No
Primary PC:
PSU tier list
https://linustechtips.com/topic/1015342-overclocking-help/#findComment-12137788
It there a calculator I can use.
I already have the card for a 600 Dollar build.
The 2600 and the 580 are a good match for each other. I wouldn't worry about bottlenecking as it should give you nice performance at 1080p anyways.
https://linustechtips.com/topic/1015342-overclocking-help/#findComment-12137789
Last question.
8 is enough, 16 recommend.
Primary PC:
PSU tier list
https://linustechtips.com/topic/1015342-overclocking-help/#findComment-12137806
Last question.
https://linustechtips.com/topic/1015342-overclocking-help/#findComment-12138117
