1440 low performance BFV
Solved by DanMottram,
9 minutes ago, White_Buffalo7.3 said:Couple things, Make sure you are on the latest drivers, make sure you are in a dual channel config(BF really likes dual) and make sure you don't have Resolution scale on 200%. Keep us up to date with your findings so others that may have an issue can find the solution.
okay so i feel pretty stupid right about now... it would appear that after updating my GPU drivers and using geforce to "optimize" my graphics settings the game had been set to 200% resolution scaling... i have no idea how i missed that but thank you all very much
i have reset the scaling to 100% the game now runs between 120 and 90 fps with DX12 Enabled
sorry to waste your time haha.
thanks.
-Dan
