Need help with case
Go to solution Solved by Acid Panda,
Just now, Acid Panda said:
what case?
you might just have to force it. wired could have got caught in the runs
A lot of people didn’t want to watch the video that i posted about my air cooling last time bc they thought it was a bit sketch, so i won’t this time. But i can’t take the back of my case off to put my powersupply through the back to the bottom of the case. I have unscrewed the only two screws on the back.
https://linustechtips.com/topic/1015165-need-help-with-case/
what case?
CPU AMD 5800x_____Asus Crosshair VIII_____Asus Strix LC 360_____RAM Corsair Dominator Pro 2x8Gb 3600mhz_____ASUS RTX 3080 Strix
PSU Corsair HX1000w_____CASE Lian Li 011 Dynamic (original choice right? w/9 UNI Fans)_____Keyboard Razer BlackWidow Chroma_____Mouse Razer Deathadder Chroma_____Headphones Bose QC25_____Monitor (1) Acer Predator XB1 144hz G-Sync  (2) Benq 144hz G-Sync
Microphone Blue Yeti Black
Razer Blade 14
Also an XBOX one s.
https://linustechtips.com/topic/1015165-need-help-with-case/#findComment-12136489
what case?
Razer Blade 14
Also an XBOX one s.
https://linustechtips.com/topic/1015165-need-help-with-case/#findComment-12136493
