So I start by saying that case is extremely bad even for budget case. It says to have AIO support at front, and based on pics I can find it sort of does. But you will need to have bracket to mount fans without radiator.
Answer to your question is that you can't have working airflow when fans are just at one spot. So for now have 1-2 exhaust, either only rear or top and rear. If you can, get bracket for front, like this https://www.overclockers.co.uk/lian-li-t60-1b-fan-bracket-for-pc-t60b-black-ca-74z-ll.html
 and add 1-2 fans to front or move one of exhausts there. Or if you have just bought the case, take it back and get something with actual fan mounts at front.
^^^^ That's my post ^^^^
vvvv Who's there? vvvv
https://linustechtips.com/topic/1015099-pc-fan-situation/#findComment-12136760
Rear and top exhaust only should work but isn't as optimal.
https://linustechtips.com/topic/1015099-pc-fan-situation/#findComment-12137812
